Datasheet TS Series (Littelfuse) - 6
Manufacturer | Littelfuse |
Description | PolySwitch Resettable PPTCs |
Pages / Page | 11 / 6 — PolySwitc. h® Resettable PTCs. Dimension Figures. Figur. e 1. Figure 2. … |
File Format / Size | PDF / 1.0 Mb |
PolySwitc. h® Resettable PTCs. Dimension Figures. Figur. e 1. Figure 2. Figure 3. e 4. Figure 5. Dimensions and Weights
A C A C A C A C A C A C B B B B B A C A C A C A C A B C A C A C A C D D A C E E D B B C to B D L CL
PolySwitc
C to E L CLE
h® Resettable PTCs
B C to B B L CL B B C to L CL Telecom > Surface Mount > TS Series B D D D E D E E E D C to L CL C to D C to L CL L CL C to L CL E E C A C to L CL C to L CL A C C C
Dimension Figures
B C D C B B D A C A C B F E E A C D D B A C F E E C D D C B B C B A D C E D A D B C B B D E A D F E B E F E D D E D D B B A A F E E D D D B A D E A E A D
Figur
A
e 1
E
Figure 2 Figure 3
C C C B F C B F B F D D E E B F A G C C D D E E E D A G C A C B C E D F B
Figur
A
e 4
F
Figure 5
C B B F F B F D D E E
D D E E A G A G B F E D D D E E E D A G A Dimensions in Millimeters (Inches) A A E C D A C A C Device Mass (g) Part Number A A B C D E F G Figure A C A C A (Only for Reference) C Min Max Min Max Min Max Min Max Min Max Min Max Min Max
TS250/TSL250/TSV250 – Surface-mount*— 250VAC
B B B A 6.7 7.9C 2.7 3.7 4.8 5.3 A0.2 0.4 C 2.5 3.1 TSL250-080F A C B A C B — — —A A — 3C C 2.80 B (0.27) (0.31) (0.11) (0.15) (0.19) (0.21) (0.01) (0.02) (0.10) (0.12) A C A C A C 6.7 7.9 2.7 3.7 4.8 5.3 0.2 0.4 2.5 3.1 TSL250-130F — — — — 3 2.80 (0.27) (0.31) (0.11) D (0.15) (0.19) (0.21) (0.01) (0.02) (0.10) D(0.12) D B B D B B 8.5 9.4 3.4 7.4 0.3‡ 3.8‡ B D B D TS250-130F E — — E — — — — — E — 1 3.60 (0.34) (0.37) B (0.14) (0.29) (0.01) (0.15) B B C to L C C to C to E L L C EL L CEL C to C 6.10 6.90 3.20 0.56 C to C 1.90 1.60 2.30 TSV250-130F L — L — — L — L — — C — to L CL 2 2.80 (0.24) D (0.27) (0.13) (0.02) (0.08) (0.07) (0.09) D D D D D 6.10 6.90 3.20 0.56 1.90 1.60 2.30 TSV250-184F A — C —D — — — D — — 2 D2.80 E E (0.24) (0.27) (0.13) (0.02) E E (0.08) (0.07) (0.09) E E C to L C C toL C to A C L C C L C to to L C C L L CL to E
TS600 – Surface-mount
L CL
E
— 600V
L CL E
AC (Single Channel)
C to L C C to C to 18.3 L 19.4 11.6 12.3 7.2 8.3 1.7 L C2.4 L 9.9 10.4 1.5 2.3 L CL TS600-170F B — — 4 23.6 (0.72) (0.77) (0.46) (0.49) (0.29) (0.33) (0.07) (0.10) (0.39) (0.41) (0.06) (0.09) B A A 18.3 19.4C C 11.6 12.3 7.2 8.3 1.7 2.4 9.9 10.4 1.5 2.3 TS600-200F — — 4 23.6 (0.72) A (0.77) (0.46) C D (0.49) (0.29) (0.33) (0.07) (0.10) (0.39) (0.41) (0.06) (0.09) E 18.3 19.4 11.6 D 12.3 7.2 8.3 1.7 2.4 9.9 10.4 1.5 2.3 TS600-400F B — — 4 19.8 C to L (0.72) CL (0.77) (0.46)B (0.49) (0.29) (0.33) (0.07) (0.10) (0.39) (0.41) (0.06) (0.09) E C to B L CL
TSM600 – Surface-mount†— 600VAC (Dual Channel)
17.0 17.60 11.20 D D 11.70 10.40 11.20 4.80 5.20 2.50 2.80 0.60 1.0 2.2 3.1 TSM600-250F 5 31.2 (0.67) (0.69) (0.44) (0.46) (0.41) (0.44) (0.19) (0.20) (0.10) (0.11) (0.02) (0.04) (0.09) (0.12) E D E C to L CL C to 17.0 17.60 11.20 11.70 10.40 11.20 4.80 5.20 2.50 2.80 0.60 1.0 2.2 3.1 TSM600-400FL CL E 5 31.2 (0.67) (0.69) (0.44) (0.46) (0.41) (0.44) (0.19) (0.20) (0.10) (0.11) (0.02) (0.04) (0.09) (0.12) C to L CL * 250VAC interrupt products may help equipment pass ITU K.20, K.21 and K.45 recommendations and Telcordia GR-1089 Port Type 2 and 4 requirements. † 600VAC interrupt products may help equipment pass UL60950, TIA-968-A and GR1089 Port Type 1, 3 and 5 requirements. ‡ Indicates dimension is typical, not minimum. © 2019 Littelfuse, Inc. Specifications are subject to change without notice. Revised: 06/05/19
