Product Brief AnD7200 (AnDAPT)
Manufacturer | AnDAPT |
Description | DrMOS Controller & Dual Sync Buck PMIC |
Pages / Page | 2 / 1 — DrMOS Controller & Dual Sync Buck PMIC. Adaptable PMIC AnD7200 |
File Format / Size | PDF / 334 Kb |
DrMOS Controller & Dual Sync Buck PMIC Adaptable PMIC AnD7200
Product Description The AnD7200 Adaptable PMIC uses AnDAPT AmP™ advanced technology consisting of fully flexible digital fabric embedded with high performance analog blocks. The AnD7200 consists of one configurable DrMOS controller, two 10A high current synchronous Buck regulators along with an integrated sequencer and four additional auxiliary LDOs. The AnD7200 is fully tested and ready for use in designs. The AnD7200 Buck regulators use voltage-mode control. The user can modify output voltages and rail sequencing using external resistors or WebAdapterTM online tool. The sequencer can be programmed based on either timed delays or Power Good (PGOOD) signals. Adaptable PMICs provide fastest prototyping and time-to-market, while providing best-in-class performance and flexibility. The Adaptable PMIC is optimized to power high-end processors by integrating multiple power rails into single-chip designs. Features Applications • One 40 A DrMOS Controller. VOUT: 0.7 V to 5 V • On-demand power management, multi-rail power • Two 10 A High Current Sync Bucks. VOUT: 0.7 V to 5.0 V integration • Protections. Input output UVLO, OCP, OVP, OTP • Powering server, processor, memory, storage, network • Four 200 mA auxiliary LDOs. V switcher and router platforms OUT: 1.2 V, 1.8 V, 2.5 V, 3.3 V • Powering FPGA, processor, SSD, subsystem power Input voltage for auxiliary LDOs is either the internal control & sequencing 4.75V LDO, or an external 5 V Product Detail • Adjustable output voltage with 2.4 mV resolution • The AnD7200 adaptable PMIC consists of one customizable 1% load regulation • DrMOS Controller, two customizable Synchronous Buck Buck regulator efficiency up to 95% • Regulators, and status pins including enable input and an PGOOD flag output and Enable input • optional PGOOD output. Soft start/stop, sequencing, pre-bias startup • –40°C to +125°C operating junction temperature • Easy WebAmP upgrade path to On-Demand PMIC Figure 1. AnD7200 WebAmP Design View Copyright © 2019 AnDAPT, Inc. 1 Product Brief 10/25/2019
