Product Brief AnD7220 (AnDAPT)
ManufacturerAnDAPT
DescriptionDrMOS Controller Dual Buck & LDO PMIC
Pages / Page2 / 1 — DrMOS Controller Dual Buck & LDO PMIC. Adaptable PMIC AnD7220
File Format / SizePDF / 522 Kb
Product Brief AnD7220 AnDAPT
DrMOS Controller Dual Buck & LDO PMIC Adaptable PMIC AnD7220
Product Description The AnD7220 Adaptable PMIC uses AnDAPT AmP™ advanced technology consisting of fully flexible digital fabric embedded with high performance analog blocks. The AnD7220 consists of one configurable DrMOS controller, one 10A high current synchronous Buck regulator, one 6A synchronous Buck regulator, two high current LDOs, along with an integrated sequencer and four additional auxiliary LDOs. The AnD7220 is fully tested and ready for use in designs. The AnD7220 Buck regulators use voltage-mode control. The user can modify output voltages and rail sequencing using external resistors or WebAdapterTM online tool. The sequencer can be programmed based on either timed delays or Power Good (PGOOD) signals. Adaptable PMICs provide fastest prototyping and time-to-market, while providing best-in-class performance and flexibility. The Adaptable PMIC is optimized to power high-end processors by integrating multiple power rails into single-chip designs. Features Applications • One 40 A DrMOS Controller. VOUT: 0.7 V to 5 V • On-demand power management, multi-rail power • One 10 A High Current Sync Buck. VOUT: 0.7 V to 5.0 V integration • One 6 A Sync Buck. V • OUT: 0.7 V to 5.0 V Powering server, processor, memory, storage, network • Two 1 A LDOs. V switcher and router platforms OUT: 0.7 V to 5.0 V • Protections. Input output UVLO, OCP, OVP, OTP • Powering FPGA, processor, SSD, subsystem power • Four 200 mA auxiliary LDOs. V control & sequencing OUT: 1.2 V, 1.8 V, 2.5 V, 3.3 V Product Detail Input voltage for auxiliary LDOs is either the internal The AnD7220 adaptable PMIC consists of one customizable 4.75V LDO, or an external 5 V DrMOS Controller, two 6A synchronous Buck regulators, • Adjustable output voltage with 2.4 mV resolution two high current LDOs and status pins including enable • 1% load regulation input and an optional PGOOD output. • Buck regulator efficiency up to 95% • PGOOD flag output and Enable input • Soft start/stop, sequencing, pre-bias startup • –40°C to +125°C operating junction temperature • Easy WebAmP upgrade path to On-Demand PMIC Figure 1. AnD7220 WebAmP Design View Copyright © 2019 AnDAPT, Inc. 1 Product Brief 10/25/2019
