Datasheet IGT40R070D1 E8220 (Infineon) - 4
Manufacturer | Infineon |
Description | CoolGaN™ 400V enhancement-mode power transistor |
Pages / Page | 16 / 4 — IGT40R070D1. E8220. 400V. CoolGaN™. enhancement-mode. Power. Transistor. … |
Revision | 02_00 |
File Format / Size | PDF / 525 Kb |
IGT40R070D1. E8220. 400V. CoolGaN™. enhancement-mode. Power. Transistor. 2. Thermal. characteristics. Table. 4. Thermal. characteristics. Parameter
IGT40R070D1 E8220 400V CoolGaN™ enhancement-mode Power Transistor 2 Thermal characteristics Table 4 Thermal characteristics Parameter Symbol Values Unit Note/Test Condition Min. Typ. Max. Thermal resistance, junction-case RthJC - - 1 °C/W Thermal resistance, junction-ambient RthJA - - 62 °C/W Device on PCB, minimum footprint Thermal resistance, junction-ambient RthJA - 35 45 °C/W Device on 40mm*40mm* for SMD version 1.5mm epoxy PCB FR4 with 6cm² (one layer, 70μm thickness) copper area for drain connection and cooling. PCB is vertical without air stream cooling. Reflow soldering temperature Tsold - - 245 °C MSL3 Final Data Sheet 4 Rev. 2.0 2018-04-25
