TSOP22.., TSOP24.., TSOP48.., TSOP44.. www.vishay.com Vishay Semiconductors IR Receiver Modules for Remote Control SystemsFEATURES • Improved immunity against HF and RF noise • Low supply current • Photo detector and preamplifier in one package • Internal filter for PCM frequency • Supply voltage: 2.5 V to 5.5 V • Improved immunity against optical noise 1 • Insensitive to supply voltage ripple and rnoise 2 • Material categorization: 3 16672 for definitions of compliance please see DESIGN SUPPORT TOOLS www.vishay.com/doc?99912 click logo to get started DESCRIPTION Models The TSOP22.., TSOP48.., TSOP24.. and TSOP44.. series Available are miniaturized IR receiver modules for infrared remote MECHANICAL DATA control systems. A PIN diode and a preamplifier are assembled on lead frame, the epoxy package contains an IR Pinning for TSOP44.., TSOP48..: filter. 1 = OUT, 2 = GND, 3 = VS The demodulated output signal can be directly connected to Pinning for TSOP22.., TSOP24..: a microprocessor for decoding. 1 = OUT, 2 = VS, 3 = GND The TSOP24.., TSOP44.. series devices are optimized to suppress almost all spurious pulses from Wi-Fi and CFL sources. They may suppress some data signals if continuously transmitted. The TSOP22.., TSOP48.. series devices are provided primarily for compatibility with old AGC2 designs. New designs should prefer the TSOP24.., TSOP44.. series containing the newer AGC4. These components have not been qualified according to automotive specifications. PARTS TABLELEGACY, FORRECOMMENDED FORAGCLONG BURST REMOTE CONTROLS (AGC2)LONG BURST CODES (AGC4) 30 kHz TSOP4830 TSOP2230 TSOP4430 TSOP2430 33 kHz TSOP4833 TSOP2233 TSOP4433 TSOP2433 Carrier 36 kHz TSOP4836 TSOP2236 TSOP4436 (1)(2)(3) TSOP2436 (1)(2)(3) frequency 38 kHz TSOP4838 TSOP2238 TSOP4438 (4)(5)(6) TSOP2438 (4)(5)(6) 40 kHz TSOP4840 TSOP2240 TSOP4440 TSOP2440 56 kHz TSOP4856 TSOP2256 TSOP4456 (6)(7) TSOP2456 (6)(7) Package Mold Pinning 1 = OUT, 2 = GND, 3 = VS 1 = OUT, 2 = VS, 3 = GND 1 = OUT, 2 = GND, 3 = VS 1 = OUT, 2 = VS, 3 = GND Dimensions (mm) 6.0 W x 6.95 H x 5.6 D Mounting Leaded Application Remote control Best choice for (1) RC-5 (2) RC-6 (3) Panasonic (4) NEC (5) Sharp (6) r-step (7) Thomson RCA Rev. 1.8, 26-Sep-2018 1 Document Number: 82459 THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
