Datasheet PI4ULS5V108Q (Diodes) - 2
ManufacturerDiodes
DescriptionAutomotive Qualified 8-BIT Bi-Directional Level Shifter for Open-Drain and Push-Pull Application
Pages / Page11 / 2 — PI4ULS5V108Q. Pin Description. Pin Name. Pin No. Description. Block …
PI4ULS5V108Q. Pin Description. Pin Name. Pin No. Description. Block Diagram. Figure 3: Block Diagram. www.diodes.com
PI4ULS5V108Q Pin Description Pin Name Pin No Description Block Diagram Figure 3: Block Diagram www.diodes.com
PI4ULS5V108Q Pin Description Pin Name Pin No. Description
GND 1 Ground. VREFA 2 Reference supply voltage A An 3-10 Data port A Bn 18-11 Data port B VREFB 19 Reference supply voltage B EN 20 Enable. Connect to VREFB and pull-up through a 200k Ω resistor
PI4ULS5V108Q
www.diodes.com
May 2019 Document Number DS41647 Rev 2-2 2 © Diodes Incorporated
