Datasheet MAX16152, MAX16153, MAX16154, MAX16155 (Maxim) - 5
ManufacturerMaxim
DescriptionnanoPower Supervisor and Watchdog Timer
Pages / Page20 / 5 — Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. …
File Format / SizePDF / 473 Kb
Electrical Characteristics (continued). PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Note 1:
Electrical Characteristics (continued) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Note 1:
MAX16152/MAX16153/ nanoPower Supervisor and Watchdog Timer MAX16154/MAX16155
((VCC = 1.2V to 5.5V, TA = -40ºC to +125ºC. Limits over the operating temperature range and relevant supply voltage range are guaranteed by production test and/or characterization. Typical values are at TA = +25ºC and VCC = VTH + 150mV.))
Manual Reset Input to t Reset Output Delay MRD 250 ns Manual Reset Internal 70 100 145 kΩ Pullup Resistor MR, WDI, WD_EN. Input connected GND Input Leakage Current -1 +1 µA or VCC
Note 1:
In addition to the specified tolerance, tRP has an uncertainty of ±4ms due to the power-up delay of internal blocks. www.maximintegrated.com Maxim Integrated | 5 Document Outline General Description Applications Benefits and Features Typical Application Circuit Absolute Maximum Ratings Package Information Electrical Characteristics Pin Configurations 6 WLP 6 SOT23 6 WLP 6 SOT23 Pin Description Functional Diagrams MAX16152/MAX16153 Block Diagram MAX16154/MAX16155 Block Diagram Detailed Description Input Threshold Watchdog Watchdog Startup Delay Watchdog Timeout Period Watchdog Enable Input (WD_EN) Watchdog Input Signal Reset Timeout Period Manual Reset Applications Information Power Supply Bypassing Watchdog Software Considerations Negative-Going VCC Transients Protection Selector Guide Ordering Information Revision History
