Datasheet PIC18F24K42, PIC18F25K42, PIC18LF24K42, PIC18LF25K42 (Microchip) - 8
Manufacturer | Microchip |
Description | 28-Pin, Low-Power High-Performance Microcontrollers with XLP Technology |
Pages / Page | 794 / 8 — PIC18(L)F24/25K42. TABLE OF CONTENTS. 1.0 Device Overview . 10 |
File Format / Size | PDF / 9.9 Mb |
PIC18(L)F24/25K42
TABLE OF CONTENTS
2.0 Guidelines for Getting Started with PIC18(L)F24/25K42 Microcontrollers . 13
3.0 PIC18 CPU. 16
4.0 Memory Organization . 23
5.0 Device Configuration . 55
6.0 Resets . 71
7.0 Oscillator Module (with Fail-Safe Clock Monitor) . 82
8.0 Reference Clock Output Module . 101
9.0 Interrupt Controller . 105
10.0 Power-Saving Operation Modes . 160
11.0 Windowed Watchdog Timer (WWDT) . 168
12.0 8x8 Hardware Multiplier. 177
13.0 Nonvolatile Memory (NVM) Control. 179
14.0 Cyclic Redundancy Check (CRC) Module with Memory Scanner. 203
15.0 Direct Memory Access (DMA) . 218
16.0 I/O Ports . 249
17.0 Peripheral Pin Select (PPS) Module . 262
18.0 Interrupt-on-Change . 270
19.0 Peripheral Module Disable (PMD). 275
20.0 Timer0 Module . 284
21.0 Timer1/3/5 Module with Gate Control. 290
22.0 Timer2/4/6 Module . 305
23.0 Capture/Compare/PWM Module . 327
24.0 Pulse-Width Modulation (PWM) . 340
25.0 Signal Measurement Timer (SMT) . 347
26.0 Complementary Waveform Generator (CWG) Module . 391
27.0 Configurable Logic Cell (CLC). 419
28.0 Numerically Controlled Oscillator (NCO) Module . 434
29.0 Zero-Cross Detection (ZCD) Module. 444
30.0 Data Signal Modulator (DSM) Module. 449
31.0 Universal Asynchronous Receiver Transmitter (UART) With Protocol Support . 460
32.0 Serial Peripheral Interface (SPI) Module. 498
33.0 I2C Module . 530
34.0 Fixed Voltage Reference (FVR) . 583
35.0 Temperature Indicator Module . 585
36.0 Analog-to-Digital Converter with Computation (ADC2) Module . 587
37.0 5-Bit Digital-to-Analog Converter (DAC) Module. 625
38.0 Comparator Module . 629
39.0 High/Low-Voltage Detect (HLVD). 638
40.0 In-Circuit Serial Programming™ (ICSP™) . 646
41.0 Instruction Set Summary . 648
42.0 Register Summary. 702
43.0 Development Support. 717
44.0 Electrical Specifications. 721
45.0 DC and AC Characteristics Graphs and Charts . 752
46.0 Packaging Information. 776
The Microchip WebSite . 791
Customer Change Notification Service . 791
Customer Support . 791
Product Identification System . 792 2016-2019 Microchip Technology Inc. DS40001869D-page 8
