Product Brief PIC18FXXQ84 (Microchip) - 3
Manufacturer | Microchip |
Description | Microcontrollers in 28/40/44/48-pin devices for many automotive and industrial application |
Pages / Page | 20 / 3 — PIC18FXXQ84. Digital Peripherals. Product Brief |
File Format / Size | PDF / 331 Kb |
PIC18FXXQ84
• 48µA @ 32 kHz, 3V, typical
Digital Peripherals
• Four 16-Bit Pulse-Width Modulators (PWM): – Dual outputs for each PWM module – Integrated 16-bit timer/counter – Double-buffered user registers for duty cycles – Right/Left/Center/Variable aligned modes of operation – Multiple clock and Reset signal selections • Three 16-Bit Timers (TMR0/1/3) • Three 8-Bit Timers (TMR2/4/6) with Hardware Limit Timer (HLT) • Two Universal Timers (TMRU16A/16B): – New Timer modules with features of TMR0/TMR1/TMR2 (Gate, Hardware Limit) – Two 16-bit timers can be chained together to create a combined 32-bit timer • Eight Configurable Logic Cell (CLC): – Integrated combinational and sequential logic • Three Complimentary Waveform Generators (CWG): – Rising and falling edge dead-band control – Full-bridge, half-bridge, 1-channel drive – Multiple signal sources – Programmable dead band – Fault-shutdown input • Three Capture/Compare/PWM (CCP) modules: – 16-bit resolution for Capture/Compare modes – 10-bit resolution for PWM mode • Three Numerically Controlled Oscillators (NCO): – Generates true linear frequency control and increased frequency resolution – Input clock up to 64 MHz • Signal Measurement Timer (SMT): – 24-bit timer/counter with prescaler – Several modes of operation like Time-of-Flight, Period and Duty Cycle measurement, etc. • Data Signal Modulator (DSM): – Multiplex two carrier clocks, with glitch prevention feature – Multiple sources for each carrier • Programmable CRC with Memory Scan: – Reliable data/program memory monitoring for Fail-Safe operation (e.g., Class B) – Calculate 16-bit CRC over any portion of Program Flash Memory • CAN Flexible Data-Rate (FD) module: – Functional in CAN FD or CAN 2.0B modes – One dedicated transmit FIFO – Three Programmable Transmit/Receive FIFOs – One Transmit Event Queue – 12 Acceptance Masks/Filters – Calculate 16-bit CRC over any portion of Program Flash Memory • Five UART modules: – LIN master and slave, DMX mode, DALI gear and device protocols – Asynchronous UART, RS-232, RS-485 compatible – Automatic and user timed BREAK period generation © 2019 Microchip Technology Inc.
Product Brief
DS40002148A-page 3 Document Outline Introduction PIC18 Q84 Family Types Features Memory Operating Characteristics Power-Saving Functionality Digital Peripherals Analog Peripherals Clocking Structure Programming/Debug Features Table of Contents 1. Packages 2. Pin Diagrams 3. Pin Allocation Tables The Microchip Website Product Change Notification Service Customer Support Microchip Devices Code Protection Feature Legal Notice Trademarks Quality Management System Worldwide Sales and Service
