Product Brief PIC18FXXQ84 (Microchip) - 4
Manufacturer | Microchip |
Description | Microcontrollers in 28/40/44/48-pin devices for many automotive and industrial application |
Pages / Page | 20 / 4 — PIC18FXXQ84. Analog Peripherals. Product Brief |
File Format / Size | PDF / 331 Kb |
PIC18FXXQ84
– Automatic checksums – Programmable 1, 1.5, and two Stop bits – Wake-up on BREAK reception – DMA compatible • Two SPI modules: – Configurable length bytes – Arbitrary length data packets – Transmit-without-receive and receive-without-transmit options – Transfer byte counter – Separate transmit and receive buffers with 2-byte FIFO and DMA capabilities • One I2C module, SMBus, PMBus™ Compatible: – 7-bit and 10-bit addressing modes with address masking modes – Dedicated address, transmit and receive buffers and DMA capabilities – Bus collision detection with arbitration – Bus time-out detection and handling – I2C, SMBus 2.0 and SMBus 3.0, and 1.8V input level selections – Multi-Master mode, including self-addressing • Device I/O Port Features: – 25 I/O pins (PIC18F26/27Q84) – 36 I/O pins (PIC18F46/47Q84) – 44 I/O pins (PIC18F56/57Q84) – Individually programmable I/O direction, open-drain, slew rate and weak pull-up control – Interrupt-on-change on most pins – Three programmable external interrupt pins • Peripheral Pin Select (PPS): – Enables pin mapping of digital I/O
Analog Peripherals
• Analog-to-Digital Converter with Computation and Context Saving (ADC3): – Up to 43 external channels – Automated math functions on input signals: • Averaging, filter calculations, oversampling and threshold comparison – 4 Separate Contexts (settings and results) saved and accessible separately – Contexts can be accessed through firmware or DMA – Operates in Sleep – Five internal analog channels – Hardware Capacitive Voltage Divider (CVD) Support: • Adjustable sample and hold capacitor array • Guard ring digital output drive • Automates touch sampling and reduces software size and CPU usage when touch or proximity sensing is required • 8-Bit Digital-to-Analog Converter (DAC): – Buffered output available on two I/O pins – Internal connections to ADC and Comparators • Two Comparators (CMP): – Four external inputs – Configurable output polarity – External output via Peripheral Pin Select • Zero-Cross Detect (ZCD): © 2019 Microchip Technology Inc.
Product Brief
DS40002148A-page 4 Document Outline Introduction PIC18 Q84 Family Types Features Memory Operating Characteristics Power-Saving Functionality Digital Peripherals Analog Peripherals Clocking Structure Programming/Debug Features Table of Contents 1. Packages 2. Pin Diagrams 3. Pin Allocation Tables The Microchip Website Product Change Notification Service Customer Support Microchip Devices Code Protection Feature Legal Notice Trademarks Quality Management System Worldwide Sales and Service
