Datasheet BTA24, BTB24, BTA25 BTA26, BTB26, T25 (STMicroelectronics) - 6
Description25 A standard and Snubberless triacs
Pages / Page12 / 6 — Ordering information scheme. BTA24, BTB24, BTA25, BTA26, BTB26, T25. …
File Format / SizePDF / 133 Kb
Ordering information scheme. BTA24, BTB24, BTA25, BTA26, BTB26, T25. Figure 12. BTA and BTB series. BT A 24 - 600 BW RG
Ordering information scheme BTA24, BTB24, BTA25, BTA26, BTB26, T25 Figure 12 BTA and BTB series BT A 24 - 600 BW RG
Ordering information scheme BTA24, BTB24, BTA25, BTA26, BTB26, T25 2 Ordering information scheme Figure 12. BTA and BTB series BT A 24 - 600 BW RG Triac series Insulation
A = insulated B = non insulated
Current
24 = 25 A in TO-220AB 25 = 25 A in RD91 26 = 25 A in TOP3
Voltage
600 = 600 V 800 = 800 V
Sensitivity and type
B = 50 mA Standard BW = 50 mA Snubberless CW = 35 mA Snubberless
Packing mode
RG = Tube
Figure 13. T25 series T 25 35 - 600 G (-TR) Triac series Current
25 = 25 A
Sensitivity
35 = 35 mA
Voltage
Package
G = D P 2 AK
Packing mode
Blank = Tube -TR = Tape and Reel 6/12 Document Outline Table 1. Device summary 1 Characteristics Table 2. Absolute maximum ratings Table 3. Electrical characteristics (Tj = 25˚ C, unless otherwise specified), Snubberless and logic level (3 quadrants) T25, BTA/BTB24...W, BTA25...W, BTA26...W Table 4. Electrical characteristics (Tj = 25˚ C, unless otherwise specified), standard (4 quadrants), BTB24...B, BTA25...B, BTA26...B, BTB26...B Table 5. Static characteristics Table 6. Thermal resistance Figure 1. Maximum power dissipation versus RMS on-state current (full cycle) Figure 2. RMS on-state current versus case temperature (full cycle) Figure 3. D2PAK RMS on-state current versus ambient temperature (printed circuit board FR4, copper thickness: 35µm) (full cycle) Figure 4. Relative variation of thermal impedance versus pulse duration Figure 5. On-state characteristics (maximum values) Figure 6. Surge peak on-state current versus number of cycles Figure 7. Non-repetitive surge peak on-state current for a sinusoidal pulse with width tp < 10 ms and corresponding value of I2t Figure 8. Relative variation of gate trigger current, holding current and latching current versus junction temperature (typical values) Figure 9. Relative variation of critical rate of decrease of main current versus (dV/dt)c (typical values) Figure 10. Relative variation of critical rate of decrease of main current versus Tj Figure 11. D2PAK thermal resistance junction to ambient versus copper surface under tab (printed circuit board FR4, copper thickness: 35 µm) 2 Ordering information scheme Figure 12. BTA and BTB series Figure 13. T25 series 3 Package information Table 7. D2PAK dimensions Figure 14. D2PAK footprint dimensions (in millimeters) Table 8. RD91 dimensions Table 9. TOP3 (insulated and non_insulated) dimensions Table 10. TO-220AB (insulated and non-insulated) dimensions 4 Ordering information Table 11. Ordering information 5 Revision history Table 12. Revision history
