Datasheet RV1S9213A (Renesas)
ManufacturerRenesas
Description1 Mbps, OPEN COLLECTOR OUTPUT, HIGH CMR, IPM DRIVER, 5-PIN SSOP WITH 8.2mm CREEPAGE DISTANCE (LSSO5) PHOTOCOUPLER
Pages / Page16 / 1 — Data. Sheet. RV1S9213A. R08DS0187EJ0100. Rev.1.00. Nov. 11,2019. 1. …
File Format / SizePDF / 6.6 Mb
Data. Sheet. RV1S9213A. R08DS0187EJ0100. Rev.1.00. Nov. 11,2019. 1. Mbps,. OPEN. COLLECTOR. OUTPUT,. HIGH. CMR,. IPM. DRIVER,. 5-PIN. SSOP. WITH. 8.2mm
Datasheet RV1S9213A Renesas
Data Sheet RV1S9213A R08DS0187EJ0100 Rev.1.00 Nov 11,2019 1 Mbps, OPEN COLLECTOR OUTPUT, HIGH CMR, IPM DRIVER, 5-PIN SSOP WITH 8.2mm CREEPAGE DISTANCE (LSSO5) PHOTOCOUPLER DESCRIPTION The RV1S9213A is an optically coupled isolator containing an AlGaAs LED on the input side and a photo diode and a signal processing circuit on the output side on one chip. The RV1S9213A is designed specifically for high common mode transient immunity (CMR) and low pulse width distortion with operating temperature. It is suitable for IPM drive. This package is very small and thin with long creepage distance(8.2mm). This small product is suitable for various interface circuits which require surface mounting and high-density mounting. FEATURES Small and long creepage (8.2 mm, LSSO5) PIN CONNECTION Open collector output (Top View) High speed switching (tPHL = 500ns Max., tPLH = 750ns MAX.) 5 4 3 Propagation Delay Difference (tPLH – tPHL = 270 ns TYP.) 1. Anode Operating temperature(-40 ~ +125°C) 2. Cathode High common mode transient immunity (CM 3. GND H, CML = 50 kV/µs MIN.) D L 4. VO High isolation voltage (BV = 5000 Vr.m.s.) IE H 5. VCC S Embossed tape product :RV1S9213ACCSP-10Yx#KC0: 3500 pcs/reel Pb-Free product Safety standard • UL :UL1577, Double protection 1 2 • CSA :CAN/CSA-C22.2 No.62368-1, Reinforced insulation • VDE :DIN EN 60747-5-5 (Option) APPLICATIONS Robot control er Industrial inverter AC Servo FA Network Measurement equipment Start of mass production Nov.2019 R08DS0187EJ0100 Rev.1.00 Page 1 of 15 Nov 11,2019
