Datasheet AL8843Q (Diodes) - 3
ManufacturerDiodes
DescriptionAutomotive Compliant 40V 3A Step-Down LED Driver
Pages / Page18 / 3 — AL8843Q. Functional Block Diagram. Absolute Maximum Ratings. Symbol. …
AL8843Q. Functional Block Diagram. Absolute Maximum Ratings. Symbol. Parameter. Rating. Unit. ESD Ratings. www.diodes.com
AL8843Q Functional Block Diagram Absolute Maximum Ratings Symbol Parameter Rating Unit ESD Ratings www.diodes.com
SET SW 3 7, 8 6 VIN VDD 4.5V AL8843Q Current Generator 4.5V_Drv Monitor Comp BG & Ref Hysteresis Logic & Reference Control PWM Driver PWM/DC PWM OTP CTRL Dimming OTP 5 1, 2 GND
(Note 5)
VIN Input Voltage -0.3 to +42 V VSW, VSET Voltage at SW pin and SET Pin -0.3 to +42 V VCTRL CTRL Pin Input Voltage -0.3 to +6 V TJ Operating Junction Temperature -40 to +150 °C TSTG Storage Temperature Range -65 to +150 °C TLEAD Lead Temperature (Soldering, 10s) +300 °C Note: 5. Stresses greater than those listed under Absolute Maximum Ratings can cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to Absolute Maximum Ratings for extended periods can affect device reliability.
ESD Ratings Symbol Parameter Rating Unit
Human Body Model (HBM), Per AEC Q100-002 ( Note 6) ±2000 VESD V Charged Device Model (CDM), Per AEC Q100-011 ±1000 Note: 6. AEC-Q100-002 indicates that HBM stressing shall be accordance with the ANSI/ESDA/JEDEC JS-001 specification. AL8843Q 3 of 18 October 2019 Document number: DS41943 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated Document Outline Pin Assignments Description Applications Features
