Datasheet MAX22700D, MAX22700E, MAX22701D, MAX22701E, MAX22702D, MAX22702E (Maxim) - 9
ManufacturerMaxim
DescriptionUltra-High CMTI Isolated Gate Drivers
Pages / Page30 / 9 — Typical Operating Characteristics. HIGH-SIDE PEAK OUTPUT CURRENT. …
Typical Operating Characteristics. HIGH-SIDE PEAK OUTPUT CURRENT. LOW-SIDE PEAK OUTPUT CURRENT. HIGH-SIDE TRANSISTOR RDSON
Typical Operating Characteristics HIGH-SIDE PEAK OUTPUT CURRENT LOW-SIDE PEAK OUTPUT CURRENT HIGH-SIDE TRANSISTOR RDSON
MAX22700D–MAX22702D Ultra-High CMTI MAX22700E–MAX22702E Isolated Gate Drivers
(VDDA - VGNDA = 5V, VDDB - VSSB = 20V, VGNDA = VSSB, TA = +25°C, unless otherwise noted.)
HIGH-SIDE PEAK OUTPUT CURRENT LOW-SIDE PEAK OUTPUT CURRENT HIGH-SIDE TRANSISTOR RDSON vs. VDDB SUPPLY VOLTAGE vs. VDDB SUPPLY VOLTAGE vs. TEMPERATURE
6.0 toc01 8 toc02 5 toc03 CL = 0.1µF, SERIES RESISTOR RS = 0.5Ω CL = 0.1µF, SERIES RESISTOR RS = 0.5Ω MAX22700/MAX22701, I 5.5 OUT = 100mA 7 4 5.0 6 ) 4.5 (Ω 5 3 MAX22700/2 N O S 4.0 PUT CURRENT (A) R D UT PUT CURRENT (A) 4 3.5 UT 2 PEAK O 3 3.0 VDDB = 13V PEAK O V 1 DDB = 13V VD V DB = 20V 2.5 2 DDB = 20V MAX22701 VD V DB = 36V DDB = 36V 2.0 1 0 12 16 20 24 28 32 36 6 12 18 24 30 36 -50 -25 0 25 50 75 100 125 VDDB SUPPLY VOLTAGE (V) V TEMPERATURE (°C) DDB SUPPLY VOLTAGE (V)
HIGH-SIDE TRANSISTOR RDSON LOW-SIDE TRANSISTOR RDSON LOW-SIDE TRANSISTOR RDSON vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
5 toc04 3.0 toc05 1.0 toc06 MAX22702, I MAX22700/MAX22702, I OUT = 100mA MAX22701, IOUT = 100mA OUT = 100mA V 2.5 0.9 DDB = 6V ONLY APPLIES TO MAX22702 4 ) 2.0 ) 0.8 (Ω (Ω 3 (Ω N N N O O S S O S R D R D 1.5 0.7 R D 2 VDDB = 6V V 1.0 0.6 VDDB = 6V V DDB = 6V DDB = 6V VD V DB = 13V VDDB = 13V V DDB = 13V VDDB = 13V V DDB = 13V 1 VD DDB = 13V V DB = 20V VDD V B = 20V DDB = 20V 0.5 VDDB = 20V V DDB = 20V DDB = 20V 0.5 VD V DB = 36V VDD V B = 36V DDB = 36V VDD V B = 36V DDB = 36V DDB = 36V 0 0.0 0.4 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
V V DDB SUPPLY CURRENT DDB SUPPLY CURRENT vs. TEMPERATURE vs. TEMPERATURE
4.0 toc07 5.5 toc08 MAX22702 MAX22700/MAX22701 INP/IN = GNDA, INN/ INP/IN = GNDA, INN/ EN = V EN = V DDA, CL = 0pF DDA, CL = 0pF 5.0 3.8 A) A) 4.5 3.6 URRENT (m 4.0 URRENT (m 3.4 VDD V B = 13V 3.5 DDB = 13V SUPPLY C VDD VDB DB= 6 = V 6V SUPPLY C VDD V B = 20V DDB = 20V VDD V B = 13V DDB = 13V 3.2 VDD V B = 25V DDB = 25V 3.0 VDD V B = 20V DDB = 20V VDD VD B DB= 3 = 6V 36V VDD V B = 36V DDB = 36V 3.0 2.5 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) www.maximintegrated.com Maxim Integrated │ 9
