Product Brief MLX81113 (Melexis) - 2
ManufacturerMelexis
DescriptionLIN RGB LED controller
Pages / Page2 / 2 — EASY APPLICATION CONFIGURATION. LC0. LC3. LC1. MLX81113. LIN_IN. LIN_OUT. …
File Format / SizePDF / 465 Kb
EASY APPLICATION CONFIGURATION. LC0. LC3. LC1. MLX81113. LIN_IN. LIN_OUT. LC2. GND
EASY APPLICATION CONFIGURATION LC0 LC3 LC1 MLX81113 LIN_IN LIN_OUT LC2 GND
k 10 bit ADC with DMA k Automotive temperature range of -40 °C to 125 °C • Multiple channels (outputs, VS, k 28 V jump start temperature sensor, IOs) k Integrated temperature sensor • Different reference voltages k Developed following ISO26262 supporting safety • Differential as well as single-ended system up to ASIL-A measurement capability k AECQ-100 qualified • DMA access k k SOIC8 package with exposed pad Low standby current consumption of typ. 25 μA (max 50 μA) in sleep mode k DFN10 3x3 package with exposed pad k Integrated battery monitor including over- and under-voltage detection
EASY APPLICATION CONFIGURATION VS
VBat
VS LC0 LC3 LC1 MLX81113 LIN_IN LIN_OUT LC2
LIN Interface with autoaddress
GND
9 -1 The above information is “as is” and believed to be correct and accurate. Melexis disclaims any and all liability in connection with or arising out of the furnishing, application or use of the information or products; any and all liability, including without limitation, special, consequential or incidental damages; 1 -1 and any and all warranties, express, statutory, implied, or by description, including warranties of fitness for particular purpose, non-infringement and merchantability. Melexis reserves the right to change it at any time and without notice. Users should obtain the latest version of the information to verify 5 it is current. Users must further determine the suitability of a product for its application, including the level of reliability required and determine whether it is fit for a particular purpose. Export control regulations may apply and export might require a prior authorization from competent authorities. /1 Melexis’ products are intended for use in normal commercial applications. Unless otherwise agreed upon in writing, the products are not designed, authorized or warranted to be suitable in applications requiring extended temperature range and/or unusual environmental requirements. High reliability 1 V applications, such as medical life-support or life-sustaining equipment are specifically not recommended by Melexis. Melexis’ products are sold under the Melexis’ Terms of Sale, which can be found at https://www.melexis.com/en/legal/terms-and-conditions.
