Datasheet IRLHM620PbF (Infineon) - 8
ManufacturerInfineon
DescriptionHEXFET Power MOSFET
Pages / Page9 / 8 — PQFN 3.3 x 3.3 Part Marking. XXXX. ?YWW?. XXXXX. PQFN 3.3 x 3.3 Tape and …
File Format / SizePDF / 542 Kb
PQFN 3.3 x 3.3 Part Marking. XXXX. ?YWW?. XXXXX. PQFN 3.3 x 3.3 Tape and Reel. REEL DIMENSIONS. TAPE DIMENSIONS
PQFN 3.3 x 3.3 Part Marking XXXX ?YWW? XXXXX PQFN 3.3 x 3.3 Tape and Reel REEL DIMENSIONS TAPE DIMENSIONS
  IRLHM620PbF
INTERNATIONAL RECTIFIER LOGO DATE CODE
XXXX
PART NUMBER ASSEMBLY SITE CODE
?YWW?
MARKING CODE (Per Marking Spec) (Per SCOP 200-002)
XXXXX
LOT CODE PIN 1 (Eng Mode - Min last 4 digits of EATI#) (Prod Mode - 4 digits of SPN code) IDENTIFIER Note: For the most current drawing please refer to IR website at http://www.irf.com/package/
DIMENSION (MM) DIMENSION (INCH) CODE MIN MAX MIN MAX Ao 3.50 3.70 .138 .146 Bo 3.50 3.70 .138 .146 Ko 1.10 1.30 .043 .051 P1 7.90 8.10 .311 .319
QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE
W 11.80 12.20 .465 .480 W 12.30 12.50 .484 .492 1 Qty 4000 Reel Diameter 13 Inches   CODE DESCRIPTION Ao Dimension design to accommodate the component width Bo Dimension design to accommodate the component lenght Ko Dimension design to accommodate the component thickness W Overall width of the carrier tape P1 Pitch between successive cavity centers   Note: For the most current drawing please refer to IR website at http://www.irf.com/package/ 8 www.irf.com © 2015 International Rectifier Submit Datasheet Feedback September 25, 2015
