Datasheet 2ED2183 (4) S06F (J) (Infineon) - 4
ManufacturerInfineon
Description650 V half-bridge gate driver with integrated bootstrap diode
Pages / Page24 / 4 — DETECT. 2ED2183S06F. R Q. Pulse. Filter. VSS/COM. LEVEL. HIN 1. SHIFT. …
Revision02_01
DETECT. 2ED2183S06F. R Q. Pulse. Filter. VSS/COM. LEVEL. HIN 1. SHIFT. Generator. 5 VCC. Deadtime & short. through provention. +5V. Delay. LIN
DETECT 2ED2183S06F R Q Pulse Filter VSS/COM LEVEL HIN 1 SHIFT Generator 5 VCC Deadtime & short through provention +5V Delay LIN
2ED2183 (4) S06F (J) 650 V half-bridge gate driver with integrated bootstrap diode 2 Block diagram
8 VB UV DETECT R 2ED2183S06F R Q 7 Pulse HO Filter S VSS/COM 6 VS LEVEL HIN 1 SHIFT Pulse
BS diode
Generator 5 VCC
DT
Deadtime & short through provention UV DETECT +5V VSS/COM LEVEL SHIFT Delay 4 LO LIN 2 Match VSS 3 COM 13 VB UV DETECT 2ED21834S06J R R Q 12 Pulse HO Filter S VSS/COM 11 VS HIN 1 LEVEL Pulse SHIFT
BS diode
Generator 7 VCC Deadtime & short DT 4 UV through DETECT provention +5V VSS/COM LEVEL SHIFT Delay 6 LO LIN 2 Match 5 COM VSS 3
Figure 2 Block diagrams Datasheet 4 of 24 V 2.10 www.infineon.com/soi 2019-09-12 Document Outline Features Product summary Product validation Description 1 Table of contents 2 Block diagram 3 Pin configuration and functionality 3.1 Pin configuration 3.2 Pin functionality 4 Electrical parameters 4.1 Absolute maximum ratings 4.2 Recommended operating conditions 4.3 Static electrical characteristics 4.4 Dynamic electrical characteristics 5 Application information and additional details 5.1 IGBT / MOSFET gate drive 5.2 Switching and timing relationships 5.3 Deadtime and matched propagation delays 5.4 Input logic compatibility 5.5 Undervoltage lockout 5.6 Bootstrap diode 5.7 Calculating the bootstrap capacitance CBS 5.8 Tolerant to negative tranisents on input pins 5.9 Negative voltage transient tolerance of VS pin 5.10 NTSOA – Negative Transient Safe Operating Area 5.11 Higher headroom for input to output signal transmission with logic operation upto -11 V 5.12 Maximum switching frequency 5.13 PCB layout tips 6 Qualification information0F 7 Related products 8 Package details 9 Part marking information 10 Additional documentation and resources 10.1 Infineon online forum resources 11 Revision history
