Datasheet AD8207 (Analog Devices) - 8
DescriptionZero Drift, High Voltage, Bidirectional Difference Amplifier
Pages / Page16 / 8 — AD8207. INPUT. 200mV/DIV. INPUT COMMON MODE. 50V/DIV. OUTPUT. 50mV/DIV. …
File Format / SizePDF / 445 Kb
AD8207. INPUT. 200mV/DIV. INPUT COMMON MODE. 50V/DIV. OUTPUT. 50mV/DIV. 2.0V/DIV. V+ = 5V. TIME (10µs/DIV). TIME (2µs/DIV). 7.0. 6.5. A) m ( T. 6.0
AD8207 INPUT 200mV/DIV INPUT COMMON MODE 50V/DIV OUTPUT 50mV/DIV 2.0V/DIV V+ = 5V TIME (10µs/DIV) TIME (2µs/DIV) 7.0 6.5 A) m ( T 6.0
AD8207 INPUT 200mV/DIV INPUT COMMON MODE 1 50V/DIV OUTPUT OUTPUT 50mV/DIV 2.0V/DIV V+ = 5V 2
2 11 2 0- 12 16 0- 09 16 09
Figure 15. Differential Overload Recovery, Rising (V+ = 5 V) Figure 18. Input Common-Mode Step Response (V+ = 5 V, Inputs Shorted)
7.0 6.5 A) m ( T 6.0 200mV/DIV N INPUT 5.5 URRE C 5.0 1 5V INK S 4.5 T U 3.3V P 4.0 T U O 3.5 OUTPUT 2.0V/DIV UM IM 3.0 V+ = 3.3V AX M 2.5
17 1
2
0- 3 16 11 0-
2.0
09 16
–40 –20 0 20 40 60 80 100 120 140
09
TIME (10µs/DIV) TEMPERATURE (°C)
Figure 16. Differential Overload Recovery, Falling (V+ = 3.3 V) Figure 19. Maximum Output Sink Current vs. Temperature
10 A) m 9 ( NT 200mV/DIV E 8 INPUT 7 5V CURR E 1 6 URC O 3.3V S 5 T U P 4 UT OUTPUT O 2.0V/DIV 3 UM V+ = 5V IM 2 AX
18 1
2
0- 14
M
1 0- 916
1
0 16 09
–40 –20 0 20 40 60 80 100 120 140 TIME (10µs/DIV) TEMPERATURE (°C)
Figure 17. Differential Overload Recovery, Falling (V+ = 5 V) Figure 20. Maximum Output Source Current vs. Temperature Rev. 0 | Page 8 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION POWER SUPPLY ADJUSTMENT 3.3 V TO 4.5 V SUPPLY OPERATION 4.5 V TO 5.5 V SUPPLY OPERATION OUTPUT OFFSET ADJUSTMENT UNIDIRECTIONAL OPERATION Ground Referenced Output Mode V+ Referenced Output Mode BIDIRECTIONAL OPERATION EXTERNAL REFERENCED OUTPUT SPLITTING THE SUPPLY SPLITTING AN EXTERNAL REFERENCE APPLICATIONS INFORMATION MOTOR CONTROL 3-Phase Motor Control H-Bridge Motor Control SOLENOID CONTROL High-Side Current Sense with a Low-Side Switch High-Side Current Sense with a High-Side Switch OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
