Datasheet AD8209 (Analog Devices) - 8
DescriptionHigh Voltage, Precision Difference Amplifier
Pages / Page16 / 8 — AD8209. Data Sheet. 12.0. 2.0. 11.5. 1.8. 11.0. m ( T 10.5. 1.6. V (. …
RevisionC
File Format / SizePDF / 366 Kb
AD8209. Data Sheet. 12.0. 2.0. 11.5. 1.8. 11.0. m ( T 10.5. 1.6. V (. 10.0. RRE. 1.4. 9.5. 1.2. 9.0. RANG E. INK CU S. 8.5. 1.0. 8.0. LTAG. 0.8. 7.5. 7.0. 0.6. M U. 6.5. 0.4
AD8209 Data Sheet 12.0 2.0 11.5 1.8 11.0 m ( T 10.5 1.6 V ( 10.0 RRE 1.4 9.5 1.2 9.0 RANG E INK CU S 8.5 1.0 8.0 LTAG 0.8 7.5 7.0 0.6 M U 6.5 0.4
AD8209 Data Sheet 12.0 2.0 11.5 A) 1.8 11.0 m ( T 10.5 ) 1.6 N V ( 10.0 E RRE 1.4 9.5 1.2 9.0 RANG E INK CU S 8.5 1.0 UT 8.0 LTAG P O 0.8 V UT 7.5 O UT 7.0 P 0.6 M U 6.5 UT IM O 0.4 X A 6.0 M 0.2 5.5 5.0
08
0 –40 –20 0 20 40 60 80 100 120 140
0 1-
0 1.0 2.0 3.0 4.0 5.0 6.0 7.0 8.0 9.0
1
TEMPERATURE (°C)
46
0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 8.5
01 1- 08
OUTPUT SINK CURRENT (mA)
46 08 Figure 10. Maximum Output Sink Current vs. Temperature Figure 13. Output Voltage Range from GND vs. Output Sink Current
6.5 ) A 6.3 m ( NT 6.0 5.8 INPUT CURRE 100mV/DIV 5.5 1 URCE O 5.3 S OUTPUT UT 5.0 P UT 4.8 O 500mV/DIV UM 4.5 IM 2 X A 4.3 M
8 01
4.1
1-
9 46 0
TIME (2µs/DIV)
0 08 1- 46
TEMPERATURE (°C)
08 Figure 11. Maximum Output Source Current vs. Temperature Figure 14. Rise Time
5.0 4.6 ) 4.2 V ( 100mV/DIV E 3.8 INPUT 3.4 RANG E 1 G 500mV/DIV 3.0 LTA O 2.6 V UT P 2.2 OUTPUT UT O 1.8 2 1.4
17 0 1- 46
1.0
08
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
0
TIME (2µs/DIV)
01 1-
OUTPUT SOURCE CURRENT (mA)
46 08 Figure 12. Output Voltage Range of A2 vs. Output Source Current Figure 15. Fall Time Rev. C | Page 8 of 16 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION HIGH-SIDE CURRENT SENSINGWITH A LOW-SIDE SWITCH HIGH-RAIL CURRENT SENSING LOW-SIDE CURRENT SENSING 4 mA to 20 mA Current Loop Receiver GAIN ADJUSTMENT Gains Less than 14 Gains Greater than 14 GAIN TRIM Internal Signal Overload Considerations LOW-PASS FILTERING HIGH LINE CURRENT SENSINGWITH LPF AND GAIN ADJUSTMENT OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
