13 /8 — AD8212. Data Sheet. 5.2. VIN. 100mV/DIV. ) V. 5.1. ( E. T = –40°C. V+ = …
Revision
C
PDF / 373 Kb
AD8212. Data Sheet. 5.2. VIN. 100mV/DIV. ) V. 5.1. ( E. T = –40°C. V+ = 15V. ROUT = 50kΩ. LTA O. T = +25°C. 5.0. OUT. 2V/DIV. T = +125°C. A L U. G E R. 4.9
AD8212Data Sheet5.2VIN100mV/DIV) V5.1( ET = –40°CV+ = 15VGROUT = 50kΩLTA OT = +25°CVV5.0OUTR2V/DIVTOT = +125°CA L U0VG E R4.9 7 01 2- 94 05 5µs/DIV4.8 4 100 200 300 400 500 600 700 800 900 1000 1100 1200 -02 42 BIAS CURRENT (µA) 59 0 Figure 16. Step Response (Gain = 50) Figure 19. Regulator Voltage High Voltage Mode (IOUT = 0 mA) vs. Bias Current 5.2VIN100mV/DIV)5.1(V EV+ = 300VAG T LV+ = 15VOV+ = 100VR5.0OUT = 20kΩR V O ATVV+ = 200VOUTUL2V/DIVG4.9RE0V 8 01 2- -007 94 42 05 4.8 059 2µs/DIV–40–25 –105203550658095110 125TEMPERATURE (°C) Figure 17. Step Response Falling Figure 20. Regulator Voltage vs. Temperature (High Voltage Operation) 550VIN500100mV/DIV450) V ( 400 GEV+ = 15VN 350RAOUT = 20kΩ300G R IN T 250A R E 200V+ MAXIMUM RANGEVOPOUT+ 150V+ MINIMUM RANGE2V/DIVV0V100 9 01 2- 50 594 0 2µs/DIV0 20 1020305070 100 150 200 250 300 350 400 450 500 -0 42 RBIAS (kΩ) 059 Figure 18. Step Response Rising Figure 21. Supply Range (V+) vs. Bias Resistor Value (High Voltage Operation) Rev. C | Page 8 of 13 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION NORMAL OPERATION (7 V TO 65 V SUPPLY (V+) RANGE) HIGH VOLTAGE OPERATION USING AN EXTERNAL PNP TRANSISTOR OUTPUT CURRENT COMPENSATION CIRCUIT APPLICATIONS INFORMATION GENERAL HIGH-SIDE CURRENT SENSING MOTOR CONTROL 500 V CURRENT MONITOR BIDIRECTIONAL CURRENT SENSING OUTLINE DIMENSIONS ORDERING GUIDE
