Datasheet ADM4073 (Analog Devices)
DescriptionLow Cost, Voltage Output, High-side Current Sense Amplifier
Pages / Page12 / 1 — Low Cost, Voltage Output,. High-Side, Current-Sense Amplifier. ADM4073. …
File Format / SizePDF / 285 Kb
Low Cost, Voltage Output,. High-Side, Current-Sense Amplifier. ADM4073. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet ADM4073 Analog Devices
Low Cost, Voltage Output, High-Side, Current-Sense Amplifier ADM4073 FEATURES FUNCTIONAL BLOCK DIAGRAM I Low cost, compact, current-sense solution LOAD 2V TO 28V RSENSE VOUT 3 available gain versions RS– 20 V/V (ADM4073T) RS+ 50 V/V (ADM4073F) I V RG1 100 V/V (ADM4073H) 3V TO 28V CC RG1 RG2 Typical ±1.0% full-scale accuracy 0.1µF Supply current: 500 μA AV Wide bandwidth: 1.8 MHz Operating supply: 3 V to 28 V Wide common-mode range: 2 V to 28 V ADM4073 Independent of supply voltage Operating temperature range: −40°C to +125°C CURRENT OUT MIRROR VOUT Available in a 6-lead SOT-23 package RGD = 12kΩ Pin-to-pin compatibility with the MAX4073 IRGD
03 0 1-
GND
13 05
Figure 1.
Cell phones PDAs APPLICATION DIAGRAM Notebook computers R Portable, battery-powered systems 2V TO 28V SENSE VOUT Smart battery packs and chargers Automotive RS+ RS– Power management systems 3V TO 28V VCC PA bias control 0.1µF OUT ADC General system-level, board-level current monitoring ADM4073 Precision current sources GND
1 -00 1 13 05 Figure 2.
GENERAL DESCRIPTION
The ADM4073 is a low cost, high-side, current-sense amplifier The voltage on the output pin is determined by the current ideal for small portable applications, such as cell phones, flowing through the selectable external sense resistor and the notebook computers, PDAs, and other systems where current gain of the version selected. The operating range is 3 V to 28 V monitoring is required. The device is available in three different with a typical supply current of 500 μA. gain models, eliminating the need for gain-setting resistors. The ADM4073 is available in a 6-lead SOT-23 package and is Because the ground path is not interrupted, the ADM4073 is specified over the automotive operating temperature range particularly useful in rechargeable battery-powered systems, (−40°C to +125°C). while its wide 1.8 MHz bandwidth makes it suitable for use inside battery-charger control loops. The input common-mode range of 2 V to 28 V is independent of the supply voltage.
Rev. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2006–2008 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM APPLICATION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RSENSE OUTPUT (OUT) OUTLINE DIMENSIONS ORDERING GUIDE
