End of Life July-2017SFH6700, SFH6701, SFH6702, SFH6705, SFH6711, SFH6712, SFH6719 www.vishay.com Vishay Semiconductors TRUTH TABLE (positive logic) PARTSIR DIODEENABLEOUTPUT on H Z SFH6700 off H Z on L H SFH6719 off L L on H SFH6701 off L on H SFH6702 off L on H SFH6705 off L on H SFH6711 off L on H SFH6712 off L ABSOLUTE MAXIMUM RATINGS (Tamb = 25 °C, unless otherwise specified) PARAMETERTEST CONDITIONSYMBOLVALUEUNITINPUT Reverse voltage VR 3 V DC forward current IF 10 mA Surge forward current t ≤ 1 μs IFSM 1 A Power dissipation Pdiss 20 mW OUTPUT Supply voltage VCC - 0.5 to + 15 V Three state enable voltage V (SFH6700, SFH6719 only) EN - 0.5 to + 15 V Output voltage VO - 0.5 to + 15 V Average output current IO 25 mA Power dissipation Pdiss 100 mW COUPLER Storage temperature range Tstg - 55 to + 150 °C Ambient temperature range Tamb + 85 °C Lead soldering temperature t = 10 s Tsld 260 °C Isolation test voltage t = 1 min VISO 5300 VRMS Pollution degree 2 Standard lead bending 7 mm Creepage distance and clearance Options 6, 7, 9 8 mm Comparative tracking index per DIN 175 IEC 112/VDE 0303, part 1 VIO = 500 V, Tamb = 25 °C RIO 1012 Ω Isolation resistance VIO = 500 V, Tamb = 100 °C RIO 1011 Ω Note • Stresses in excess of the absolute maximum ratings can cause permanent damage to the device. Functional operation of the device is not implied at these or any other conditions in excess of those given in the operational sections of this document. Exposure to absolute maximum ratings for extended periods of the time can adversely affect reliability Rev. 1.7, 07-Feb-17 2 Document Number: 83683 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
