End of Life July-2017SFH6700, SFH6701, SFH6702, SFH6705, SFH6711, SFH6712, SFH6719 www.vishay.com Vishay Semiconductors ICC ICC VCC VCC IF (8) IF (8) A A (2) I (2) O IO VO VO (7) (6) I K E K (3) VEN(6) (3) GND GND Shield (5) Shield (5) SFH6700, SFH6719 SFH6702, SFH6712 ICC ICC VCC VCC IF (8) IF (8) A A (2) I I (2) O O VO VO (6) (7) K K (3) (3) GND GND Shield (5) Shield (5) SFH6701, SFH6711 SFH6705 isfh6700_01 Fig. 1 - Schematics RECOMMENDED OPERATING CONDITIONS PARAMETERTEST CONDITIONPARTSYMBOLMIN.TYP.MAX.UNIT Supply voltage VCC 4.5 15 V SFH6700 VEH 2 15 V Enable voltage high SFH6719 VEH 2 15 V SFH6700 VEL 0 0.8 V Enable voltage low SFH6719 VEL 0 0.8 V IFon 1.6 (2) 5 mA Forward input current IFoff 0.1 mA Operating temperature Tamb - 40 85 °C Output pull-up resistor SFH6705 RL 350 4 kΩ LS TTL Fan output RL = 1 kΩ SFH6705 N 16 loads Notes • A 0.1 μF bypass capacitor connected between pins 5 and 8 must be used (1) We recommended using a 2.2 mA to permit at least 20 % CTR degradation guard band ELECTRICAL CHARACTERISTICS PARAMETERTEST CONDITIONSYMBOLMIN.TYP.MAX.UNITINPUT IF = 5 mA VF 1.6 1.75 V Forward voltage IF = 5 mA VF 1.8 V Input current hysteresis VCC = 5 V, IHYS = IFon - IFoff IHYS 0.1 mA Reverse current VR = 3 V IR 0.5 10 μA Capacitance VR = 0 V, f = 1 MHz CO 60 pF Thermal resistance RthJA 700 K/W OUTPUT Logic low output voltage IOL = 6.4 mA VOL 0.5 V Logic high output voltage I (except SFH6705) OH = 2.6 mA, VOH = VCC - 1.8 V 2.4 V Rev. 1.7, 07-Feb-17 3 Document Number: 83683 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
