End of Life July-2017SFH6700, SFH6701, SFH6702, SFH6705, SFH6711, SFH6712, SFH6719 www.vishay.com Vishay Semiconductors SWITCHING CHARACTERISTICS PARAMETERTEST CONDITIONPARTSYMBOLMIN.TYP.MAX.UNIT Output disable time from logic low (SFH6700, SFH6719) (1) tPLZ 50 ns Output rise time (1) 10 % to 90 % tr 40 ns Output fall time (1) 90 % to 10 % tf 10 ns Without peaking capacitor SFH6705 tPHL 115 ns Propagation delay time to logic With peaking capacitor SFH6705 tPHL 105 300 ns low output level (3) Without peaking capacitor SFH6705 tPLH 125 ns With peaking capacitor SFH6705 tPLH 90 300 ns 10 % to 90 % tr 25 ns Output rise time (3) 90 % to 10 % tr 4 ns Notes • 0 °C ≤ Tamb ≤ 85 °C; 4.5 V ≤ VCC ≤ 15 V; 1.6 mA ≤ IFon ≤ 5 mA; 2 ≤ VEH ≤ 15 V (SFH6700/19); 0 ≤ VEL ≤ 0.8 V (SFH6700, SFH6719); 0 mA ≤ IFoff ≤ 0.1 mA (1) Typical values: Tamb = 25 °C; VCC = 5 V; IFon = 3 mA unless otherwise specified (4) (2) Typical values: Tamb = 25 °C, VCC = 5 V; IFon = 3 mA; RL = 390 Ω unless otherwise specified (4) (3) A 0.1 μF bypass capacitor connected between pins 5 and 8 must be used COMMON MODE TRANSIENT IMMUNITY PARAMETERTEST CONDITIONPARTSYMBOLMIN.TYP.MAX.UNIT SFH6700 |CMH| (1) 1000 V/μs SFH6701 |CMH| (1) 1000 V/μs |VCM| = 50 V, IF = 1.6 mA SFH6702 |CMH| (1) 1000 V/μs Logic high common mode SFH6705 |CM transient immunity H| (1) 1000 V/μs SFH6711 |CMH| (1) 2500 V/μs |VCM| = 400 V, IF = 1.6 mA SFH6712 |CMH| (1) 2500 V/μs SFH6719 |CMH| (1) 2500 V/μs |VCM| = 50 V, IF = 0 mA SFH6700 |CML| (2) 1000 V/μs SFH6701 |CML| (2) 1000 V/μs |VCM| = 50 V, IF = 0 mA SFH6702 |CML| (2) 1000 V/μs Logic Low common mode SFH6705 |CM transient immunity L| (2) 1000 V/μs SFH6711 |CML| (2) 2500 V/μs |VCM| = 400 V, IF = 0 mA SFH6712 |CML| (2) 2500 V/μs SFH6719 |CML| (2) 2500 V/μs Notes • Tamb = 25 °C, VCC = 5 V (1) CMH is the maximum slew rate of a common mode voltage VCM at which the output voltage remains at logic high level (VO > 2 V) (2) CML is the maximum slew rate of a common mode voltage VCM at which the output voltage remains at logic high level (VO < 0.8 V) Rev. 1.7, 07-Feb-17 5 Document Number: 83683 For technical questions, contact: optocoupleranswers@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
