Datasheet ZPY3V9 - ZPY100 (Vishay) - 2
ManufacturerVishay
DescriptionZener Diodes
Pages / Page5 / 2 — ZPY3V9 to ZPY100. ELECTRICAL CHARACTERISTICS. DYNAMIC. ADMISSIBLE. …
File Format / SizePDF / 108 Kb
ZPY3V9 to ZPY100. ELECTRICAL CHARACTERISTICS. DYNAMIC. ADMISSIBLE. TEMPERATURE. ZENER VOLTAGE. TEST. REVERSE. RESISTANCE. ZENER
ZPY3V9 to ZPY100 ELECTRICAL CHARACTERISTICS DYNAMIC ADMISSIBLE TEMPERATURE ZENER VOLTAGE TEST REVERSE RESISTANCE ZENER
ZPY3V9 to ZPY100
(Tamb = 25 °C, unless otherwise specified)
DYNAMIC ADMISSIBLE TEMPERATURE ZENER VOLTAGE TEST REVERSE RESISTANCE ZENER COEFFICIENT OF ZENER RANGE (2) CURRENT VOLTAGE f = 1 kHz CURRENT (1) VOLTAGE PART NUMBER VZ at IZT1 IZT1 VR at IR ZZ at IZT1 IZ TCVZ at IZT1 V mA V μA mA 10-4/°C MIN. NOM. MAX. TYP. MIN. MAX.
ZPY3V9 3.7 3.9 4.1 100 - 0.5 4 (< 7) 290 - 7 2 ZPY4V3 4 4.3 4.6 100 - 0.5 4 (< 7) 260 - 7 3 ZPY4V7 4.4 4.7 5 100 - 0.5 4 (< 7) 235 - 7 4 ZPY5V1 4.8 5.1 5.4 100 > 0.7 0.5 2 (< 5) 215 - 6 5 ZPY5V6 5.2 5.6 6 100 > 1.5 0.5 1 (< 2) 193 - 3 5 ZPY6V2 5.8 6.2 6.6 100 > 2.0 0.5 1 (< 2) 183 - 1 6 ZPY6V8 6.4 6.8 7.2 100 > 3.0 0.5 1 (< 2) 157 0 7 ZPY7V5 7 7.5 7.9 100 > 5.0 0.5 1 (< 2) 143 0 7 ZPY8V2 7.7 8.2 8.7 100 > 6.0 0.5 1 (< 2) 127 3 8 ZPY9V1 8.5 9.1 9.6 50 > 7.0 0.5 2 (< 4) 117 3 8 ZPY10 9.4 10 10.6 50 > 7.5 0.5 2 (< 4) 105 5 9 ZPY11 10.4 11 11.6 50 > 8.5 0.5 3 (< 7) 94 5 10 ZPY12 11.4 12 12.7 50 > 9.0 0.5 3 (< 7) 85 5 10 ZPY13 12.4 13 14.1 50 > 10 0.5 4 (< 9) 78 5 10 ZPY15 13.8 15 15.8 50 > 11 0.5 4 (< 9) 70 5 10 ZPY16 15.3 16 17.1 25 > 12 0.5 5 (< 10) 63 7 11 ZPY18 16.8 18 19.1 25 > 14 0.5 5 (< 11) 57 7 11 ZPY20 18.8 20 21.2 25 > 15 0.5 6 (< 12) 52 7 11 ZPY22 20.8 22 23.3 25 > 17 0.5 7 (< 13) 48 7 11 ZPY24 22.8 24 25.6 25 > 18 0.5 8 (< 14) 42 7 12 ZPY27 25.1 27 28.9 25 > 20 0.5 9 (< 15) 38 7 12 ZPY30 28 30 32 25 > 22.5 0.5 10 (< 20) 35 7 12 ZPY33 31 33 35 25 > 25 0.5 11 (< 20) 31 7 12 ZPY36 34 36 38 10 > 27 0.5 25 (< 60) 29 7 12 ZPY39 37 39 41 10 > 29 0.5 30 (< 60) 26 8 12 ZPY43 40 43 46 10 > 32 0.5 35 (< 80) 24 8 13 ZPY47 44 47 50 10 > 35 0.5 40 (< 80) 22 8 13 ZPY51 48 51 54 10 > 38 0.5 45 (< 100) 20 8 13 ZPY56 52 56 60 10 > 42 0.5 50 (< 100) 18 8 13 ZPY62 58 62 66 10 > 47 0.5 60 (< 130) 16 8 13 ZPY68 64 68 72 10 > 51 0.5 65 (< 130) 14 8 13 ZPY75 70 75 79 10 > 56 0.5 70 (< 160) 13 8 13 ZPY82 77 82 88 10 > 61 0.5 80 (< 160) 12 8 13 ZPY91 85 91 96 5 > 68 0.5 120 (< 250) 11 9 13 ZPY100 94 100 106 5 > 75 0.5 130 (< 250) 10 9 13
Notes
(1) Valid provided that leads are kept at ambient temperature at a distance of 10 mm from case (2) Tested with pulses tp = 5 ms Rev. 2.2, 12-Mar-2019
2
Document Number: 85790 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
