Datasheet ST7LITEUSx (STMicroelectronics) - 9
Manufacturer | STMicroelectronics |
Description | 8-bit MCU with single voltage Flash memory, ADC, timers. ST7ULTRALITE (ST7LITEUS2, ST7LITEUS5) |
Pages / Page | 108 / 9 — ST7LITEUSx. Table 2. Hardware Register Map. Register. Address. Block. … |
File Format / Size | PDF / 889 Kb |
ST7LITEUSx. Table 2. Hardware Register Map. Register. Address. Block. Register Name. Reset Status. Remarks. Label
ST7LITEUSx Table 2. Hardware Register Map Register Address Block Register Name Reset Status Remarks Label
0000h PADR Port A Data Register 00h 1) R/W 0001h Port A PADDR Port A Data Direction Register 08h R/W 0002h PAOR Port A Option Register 02h 2) R/W 0003h- Reserved area (8 bytes) 000Ah 000Bh LITE LTCSR Lite Timer Control/Status Register 0xh R/W 000Ch TIMER LTICR Lite Timer Input Capture Register 00h Read Only 000Dh ATCSR Timer Control/Status Register 00h R/W 000Eh CNTRH Counter Register High 00h Read Only 000Fh AUTO- CNTRL Counter Register Low 00h Read Only 0010h RELOAD ATRH Auto-Reload Register High 00h R/W 0011h TIMER ATRL Auto-Reload Register Low 00h R/W 0012h PWMCR PWM Output Control Register 00h R/W 0013h PWM0CSR PWM 0 Control/Status Register 00h R/W 0014h to Reserved area (3 bytes) 0016h AUTO- 0017h DCR0H PWM 0 Duty Cycle Register High 00h R/W RELOAD 0018h DCR0L PWM 0 Duty Cycle Register Low 00h R/W TIMER 0019h to Reserved area (22 bytes) 002Eh 0002Fh FLASH FCSR Flash Control/Status Register 00h R/W 0030h to Reserved area (4 bytes) 0033h 0034h ADCCSR A/D Control Status Register 00h R/W 0035h ADC ADCDRH A/D Data Register High xxh Read Only 0036h ADCDRL A/D Data Register Low 00h R/W 0037h ITC EICR1 External Interrupt Control Register 1 00h R/W 0038h MCC MCCSR Main Clock Control/Status Register 00h R/W 0039h Clock and RCCR RC oscillator Control Register FFh R/W 003Ah Reset SICSR System Integrity Control/Status Register 0000 0x00b R/W 003Bh to Reserved area (2 bytes) 003Ch 003Dh ITC EICR2 External Interrupt Control Register 2 00h R/W 003Eh AVD AVDTHCR AVD Threshold Selection Register 03h R/W Clock 003Fh CKCNTCSR Clock Controller Control/Status Register 09h R/W controller 0040h to Reserved area (7 bytes) 0046h 9/108 1
