Datasheet NL27WZ14 (ON Semiconductor) - 9
Manufacturer | ON Semiconductor |
Description | Dual Inverter with Schmitt Trigger Input |
Pages / Page | 12 / 9 — NL27WZ14. PACKAGE DIMENSIONS. SC−74. MILLIMETERS. INCHES. DIM. MIN. NOM. … |
Revision | 15 |
File Format / Size | PDF / 190 Kb |
NL27WZ14. PACKAGE DIMENSIONS. SC−74. MILLIMETERS. INCHES. DIM. MIN. NOM. MAX. SOLDERING FOOTPRINT*. www.onsemi.com
NL27WZ14 PACKAGE DIMENSIONS SC−74
CASE 318F−05 ISSUE N
D
NOTES: 1. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. 2. CONTROLLING DIMENSION: INCH. 3. MAXIMUM LEAD THICKNESS INCLUDES LEAD FINISH THICKNESS. MINIMUM LEAD THICKNESS IS THE MINIMUM
6 5 4
THICKNESS OF BASE MATERIAL.
H E
4. 318F−01, −02, −03, −04 OBSOLETE. NEW STANDARD 318F−05.
E 1 2 3 MILLIMETERS INCHES DIM MIN NOM MAX MIN NOM MAX b A
0.90 1.00 1.10 0.035 0.039 0.043
A1
0.01 0.06 0.10 0.001 0.002 0.004
e b
0.25 0.37 0.50 0.010 0.015 0.020
c
0.10 0.18 0.26 0.004 0.007 0.010
D
2.90 3.00 3.10 0.114 0.118 0.122
E
1.30 1.50 1.70 0.051 0.059 0.067
q c e
0.85 0° 0.95 1.05 10° 0.034 0° 0.037 0.041 10°
A L
0.20 0.40 0.60 0.008 0.016 0.024 0.05 (0.002)
HE
2.50 2.75 3.00 0.099 0.108 0.118
q
A1 L SOLDERING FOOTPRINT*
2.4 0.094 0.95 1.9 0.037 0.074 0.95 0.7 0.037 0.028 1.0 SCALE 10:1 ǒ mm Ǔ 0.039 inches *For additional information on our Pb−Free strategy and soldering details, please download the ON Semiconductor Soldering and Mounting Techniques Reference Manual, SOLDERRM/D. STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: STYLE 6: PIN 1. CATHODE PIN 1. NO CONNECTION PIN 1. EMITTER 1 PIN 1. COLLECTOR 2 PIN 1. CHANNEL 1 PIN 1. CATHODE 2. ANODE 2. COLLECTOR 2. BASE 1 2. EMITTER 1/EMITTER 2 2. ANODE 2. ANODE 3. CATHODE 3. EMITTER 3. COLLECTOR 2 3. COLLECTOR 1 3. CHANNEL 2 3. CATHODE 4. CATHODE 4. NO CONNECTION 4. EMITTER 2 4. EMITTER 3 4. CHANNEL 3 4. CATHODE 5. ANODE 5. COLLECTOR 5. BASE 2 5. BASE 1/BASE 2/COLLECTOR 3 5. CATHODE 5. CATHODE 6. CATHODE 6. BASE 6. COLLECTOR 1 6. BASE 3 6. CHANNEL 4 6. CATHODE STYLE 7: STYLE 8: STYLE 9: STYLE 10: STYLE 11: PIN 1. SOURCE 1 PIN 1. EMITTER 1 PIN 1. EMITTER 2 PIN 1. ANODE/CATHODE PIN 1. EMITTER 2. GATE 1 2. BASE 2 2. BASE 2 2. BASE 2. BASE 3. DRAIN 2 3. COLLECTOR 2 3. COLLECTOR 1 3. EMITTER 3. ANODE/CATHODE 4. SOURCE 2 4. EMITTER 2 4. EMITTER 1 4. COLLECTOR 4. ANODE 5. GATE 2 5. BASE 1 5. BASE 1 5. ANODE 5. CATHODE 6. DRAIN 1 6. COLLECTOR 1 6. COLLECTOR 2 6. CATHODE 6. COLLECTOR
www.onsemi.com 9
