Chassis Mount 241 Series Two-4-One™ Power Transformers Split Bobbin Construction Providing Superior Isolation Signal’s 241 transformers use a split bobbin construction that provides superior isolation and low capacitive coupling. General Specifications • Power - 2.4 VA to 100 VA • Dielectric Strength - 2500 Vrms Hipot • Primaries - Single or dual primaries (115 V or 115/230 V - 50/60 Hz) • Secondary - Single center tapped secondary • Terminals - Solder lug / quick connect type terminals • Insulation - Class B (130° C) UL 1446 E66312 Agency Certifications • UL recognized to UL 506 / UL 5085-1, File # E63829 • CSA certified to C22.2 #66.1, File # 221070 RoHS Compliant belfuse.com/signal
