Datasheet PT7C4363BQ (Diodes)
Manufacturer | Diodes |
Description | Automotive Real Time Clock |
Pages / Page | 23 / 1 — PT7C4363BQ. Automotive Real-time Clock. Features. Description. Table 1. … |
File Format / Size | PDF / 911 Kb |
PT7C4363BQ. Automotive Real-time Clock. Features. Description. Table 1. Item. Function. www.diodes.com
PT7C4363BQ Automotive Real-time Clock Features Description
• Drop-In Replacement for PT7C4363 The PT7C4363BQ serial real-time clock is an automotive low- • Supports High-ESR Crystals Up To 100kΩ power clock/calendar with a programmable square-wave • Supports alarm and timer output. • Supports I2C-Bus's high speed mode (400 kHz) • Includes time (Hour/Minute/Second) and calendar Address and data are transferred serially via a 2-wire (Year/Month/Date/Day) counter functions (BCD code) bidirectional bus. The clock/calendar provides seconds, • Low backup current: typ. 400nA at VDD=3.0V and minutes, hours, day, date, month, and year information. TA=25°C The date at the end of the month is automatical y adjusted for • Operating range: 1.3V to 5.5V months with fewer than 31 days, including corrections for leap • Extended Operating Temp: -40°C to 125°C year. The clock operates in the 24-hour format indicator. • AECQ-100 Compliant for Automotive Application • Totally Lead-Free & Ful y RoHS Compliant (Notes 1 & 2) Table 1 shows the basic functions of PT7C4363BQ. More • Halogen and Antimony Free. “Green” Device (Note 3) details are shown in section: overview of functions. • PPAP Capable (Note 4) • Packaging (Pb-free & Green): 8-Pins, SOIC (W)
Table 1.
Basic functions of PT7C4363BQ
Item Function PT7C4363BQ
Source: Crystal: 32.768kHz √ 1 Oscillator Oscillator enable/disable - Oscillator fail detect √ 12-hour - Time display 24-hour √ 2 Time Century bit √ Time count chain enable/disable √ Alarm interrupt √ 3 Interrupt Timer interrupt output √ 4 Programmable square wave output (Hz) 1, 32, 1.024k, 32.768k 2-wire I2C bus √ Communicati 5 3-wire bus - on Burst mode - Write protection - 6 Control External clock test mode √ Power-on reset override √ Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. Automotive products are AEC-Q100 qualified and are PPAP capable. Refer to https://www.diodes.com/quality/. PT7C4363BQ
www.diodes.com
July 2019 Document Number DS42042 Rev 1-2 1 © Diodes Incorporated Document Outline Features Description Pin Configuration Pin Description Function Block Maximum Ratings Recommended Operating Conditions DC Electrical Characteristics AC Electrical Characteristics Recommended Layout for Crystal Cpar is all parasitical capacitor between X1 and X2. Crystal Specifications Function Description Overview of Functions Registers Control and Status Register Time Counter Days of the Week Counter Calendar Counter AE W4 Communication I2C Bus Interface Overview of I2C-BUS System Configuration Starting and Stopping I2C Bus Communications Slave Address Part Marking Mechanical Information
