Datasheet PT7C4563BQ (Diodes)
ManufacturerDiodes
DescriptionAutomotive Grade Real-time Clock
Pages / Page19 / 1 — PT7C4563BQ. Automotive Grade Real-time Clock. Features. Description. …
PT7C4563BQ. Automotive Grade Real-time Clock. Features. Description. Table 1. Item. Function. PT7C4563B. www.diodes.com
Datasheet PT7C4563BQ Diodes
PT7C4563BQ Automotive Grade Real-time Clock Features Description
• Drop-in Replacement for PT7C4563 The PT7C4563BQ serial real-time clock is an automotive- • Supports High-ESR Crystals up to 100kΩ grade low-power clock/calendar with a programmable square- • Uses External 32.768kHz Quartz Crystal wave output. It supports up to 125°C operating temperature. • Supports I2C Bus' High-Speed Mode (400kHz) • Includes Time (Hour/Minute/Second) and Calendar Address and data are transferred serially via a 2-wire (Year/Month/Date/Day) Counter Functions (BCD Code) bidirectional bus. The clock/calendar provides seconds, • Programmable Square Wave Output Signal minutes, hours, day, date, month, and year information. • Oscillator Stop Flag • Low Backup Current: Typ. 400nA at VDD=3.0V and The date at the end of the month is automatical y adjusted for TA=25°C months with fewer than 31 days—including corrections for • Operating Range: 1.3V to 5.5V leap year. The clock operates in the 24-hour format indicator. • Extended Operating Temp: -40°C to 125°C • AECQ-100 Compliant for Automotive Application Table 1 shows the basic functions of PT7C4563BQ. More • Totally Lead-Free & Ful y RoHS Compliant (Notes 1 & 2) details are shown in the Overview of Functions section. • Halogen and Antimony Free. “Green” Device (Note 3) • PPAP Capable (Note 4) • Packaging (Pb-free & Green): 8-Pins, SOIC (W)
Table 1.
Basic Functions of PT7C4563BQ
Item Function PT7C4563B
Source: Crystal: 32.768kHz √ 1 Oscillator Oscillator Enable/Disable - Oscillator Fail Detect √ Time 12-Hour - Display 24-Hour √ 2 Time Century Bit - Time Count Chain Enable/Disable - 3 Interrupt Alarm Interrupt √ 4 Programmable Square Wave Output (Hz) 1, 32, 1.024k, 32.768k 2-Wire I2C Bus √ 5 Communication Burst Mode - Notes: 1. No purposely added lead. Fully EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. Automotive products are AEC-Q100 qualified and are PPAP capable. Refer to https://www.diodes.com/quality/. PT7C4563BQ
www.diodes.com
July 2019 Document Number DS41477 Rev 2-2 1 © Diodes Incorporated Document Outline Features Description Pin Configuration Pin Description Function Block Maximum Ratings Recommended Operating Conditions DC Electrical Characteristics AC Electrical Characteristics Recommended Layout for Crystal Cpar = all parasitical capacitor between X1 and X2 Crystal Specifications Function Description Overview of Functions Registers Control and Status Register Time Counter Days of the Week Counter Calendar Counter Communication I2C Bus Interface Overview of I2C Bus System Configuration Starting and Stopping I2C Bus Communications Slave Address Part Marking Packaging Mechanical W (SOIC-8)
