CMX655DUltra Low Power Voice Codec D/655/4 October 2019 Provisional FeaturesApplicationsDigital microphone supportSecurity alarm panelsHigh efficiency Class-D amplifierGlass break detectionUltra Low power consumptionIntercom and access systems16 bit audio dataMobile radio and accessoriesSupports conventional telephony and HD voice (300Hz - 3.4kHzWired telephonyand 50Hz -7kHz bandwidths)Voice controlled equipmentSupports audio bandwidths up to 21kHzSupports 8/16/32/48 ksps sample ratesFlexible serial audio interfaceSPI™/TWI control interface1Small 24-lead VQFN Package PLL and Signal RCLK igital Filtering internal osc D terface PDM to decimated processing 16 bit PCM In LRCLK/FS I2S/PCM audio BCLK interface DO DI Control registers and logic Digital sidetone Optional second microphone CSN/A0 Line out SPI/TWI control MISOSDA interface SCLK/SCL MOSI/A1 RSTN Class D Digital gain IRQN Filtering driver control VSS Supplies VDD Figure 1 CMX655D Simplified Block Diagram1Brief Description Traditionally audio codecs have interfaced to electret microphones and speakers providing A-to-D and D-to-A functions using precision oversampling data converters. Recent advances in microphone design using MEMS techniques are now changing this, along with higher efficiency speaker drivers such as Class-D topologies. Both of these advances enable significant reductions in power consumption which is needed to address new applications such as voice control, that require ‘always-on’ operation. Such applications are often battery powered, driving the need for minimal power consumption. The CMX655D addresses these needs providing an update to the traditional audio codec that is both very low power and small in size. The CMX655D has a digital microphone interface that connects single or dual microphones to the device and the same parallel processing streams. A 1-Watt mono Class-D amplifier drives differential audio outputs for a filterless speaker. A separate single-ended analogue lineout is also provided for a headphone. The Class-D amplifier features programmable filtering and digital gain control. This architecture operates with far higher efficiency than conventional speaker drivers. The device interfaces via standard serial busses that are commonly found on many microcontrollers, DSPs and low cost radio transceivers. 1 SPI™ is a trademark of Motorola Inc. 2019 CML Microsystems Plc Document Outline Datasheet Front Page 1 Brief Description 2 Block Diagram 2.1 CMX655D 3 Pin List 3.1 CMX655D 4 External Components 4.1 CMX655D 4.1.1 Power Supply and Pin Decoupling 4.1.2 SPI 4.1.3 TWI 4.1.4 Speaker and Microphone 5 General Description 5.1 Power Management 5.1.1 External Supplies 5.1.2 Regulated Supplies 5.2 Device Reset 5.2.1 Power-On-Reset 5.2.2 Reset Pin 5.3 Main Clock 5.3.1 Clock Frequency 5.3.2 Clock Generation 5.3.3 PLL 5.3.4 Low Power Oscillator 5.3.5 Clock Control Registers 5.3.5.1 CLKCTRL ($03) 5.3.5.2 RDIVHI ($04) 5.3.5.3 RDIVLO ($05) 5.3.5.4 NDIVHI ($06) 5.3.5.5 NDIVLO ($07) 5.3.5.6 PLLCTRL ($08) 5.4 Microphone Interface 5.4.1 Digital Microphone Interface 5.5 Class-D Amplifier 5.5.1 Audio Outputs 5.5.2 Overload Current Protection 5.5.3 Thermal Protection 5.5.4 Clipping Detection 5.6 Audio Signal Processing 5.6.1 Record Level Control 5.6.1.1 Record Level Control Register 5.6.2 Noise Gate 5.6.2.1 Noise Gate Registers 5.6.3 Record Level Detection 5.6.3.1 Record Level Detection Registers 5.6.4 Playback Preamplifier Gain 5.6.4.1 Playback Preamplifier Gain Register 5.6.5 Playback Volume Control 5.6.5.1 Playback Volume Register 5.6.6 Automatic Level Control 5.6.6.1 ALC Registers 5.6.7 Digital Sidetone 5.6.7.1 Digital Sidetone Register 5.6.8 Voice Filters 5.6.8.1 Low Pass Filter 5.6.8.2 DC Blocking Filter 5.6.8.3 High Pass Filter 5.6.8.4 Voice Filters Registers 5.6.9 Channel Multiplexing 5.6.10 Click-and-Pop Reduction 5.6.10.1 Click-and-Pop Reduction Register 5.7 Control Interface 5.7.1 SPI Slave 5.7.2 TWI Slave 5.8 Serial Audio Interface 5.8.1 I2S Mode 5.8.2 Left-Justified Mode 5.8.3 PCM Mode 5.8.4 Audio Companding 5.8.5 Serial Audio Interface Registers 5.9 Interrupt Status and IRQN Pin 5.9.1 Interrupt Registers 5.10 System Control 5.10.1 System Control Registers 5.11 Register Address Map 6 Application Notes 6.1 Programming Examples 6.1.1 Start-up 6.1.2 Configuration 6.1.3 Enable Audio Channels 6.1.4 Shutdown 7 Performance Specification 7.1 Electrical Performance 7.1.1 Absolute Maximum Ratings 7.1.2 Operating Limits 7.1.3 Operating Characteristics 7.1.3.1 DC Parameters 7.1.3.2 AC Parameters 7.1.3.3 SPI 7.1.3.4 TWI 7.1.3.5 SAI 7.1.3.6 Digital Microphone Interface 7.2 Typical Performance Characteristics 7.2.1 THD+N vs. Level performance 7.2.2 THD+N vs. Frequency performance 7.2.3 Class D Amplifier Efficiency 7.2.4 Filter Performance Speaker Channel 7.2.5 Filter Performance Microphone Channel 7.3 Packaging 7.3.1 CMX655D End of Document cmlmicro.com CMX655D - Ultra-low Power Voice Codec - CML Micro
