Datasheet CMX655D (CML Microcircuits) - 6
Manufacturer | CML Microcircuits |
Description | Ultra Low Power Voice Codec |
Pages / Page | 64 / 6 — Pin List. 3.1. CMX655D. Table 1 CMX655D Pin List by Number. Number. Name. … |
Revision | 4 |
File Format / Size | PDF / 3.3 Mb |
Pin List. 3.1. CMX655D. Table 1 CMX655D Pin List by Number. Number. Name. Type. Function
Ultra-Low Power Voice Codec CMX655D
3 Pin List 3.1 CMX655D Table 1 CMX655D Pin List by Number Number Name Type Function
1 AOUTN AO Class-D Amplifier Output Negative 2 VDD_PA VDD Class-D Supply: 2.7-3.6V (high current) 3 LOUT AO Lineout 4 VDD_A VDD 1.2V Regulator Decouple 5 BIAS AO Bias Current Resistor 6 NC1 NC No Connection 7 VDD_AD1 VDD Analogue/Digital Supply 2.7-3.6V (1.75-3.6V if VDD_PA unused) 8 VDD_AD2 VDD Analogue/Digital Supply 2.7-3.6V (1.75-3.6V if VDD_PA unused) 9 RSTN DI Active Low Reset 10 MICCLK DO Digital Microphone Clock Output 11 MICDI DI Digital Microphone Data Input 12 RCLK DI PLL Reference/Main clock 13 LRCLK/FS DIO Left-Right Clock/PCM Frame Sync/PLL Reference 14 SDI DI Serial Audio Data Input 15 SDO DO Serial Audio Data Output 16 BCLK DIO Serial Audio Data Clock 17 SPIS DI SPI Select: 0=TWI, 1=SPI 18 IRQN DO Active Low Interrupt. Open-drain – connect to VDD_AD via pull up 19 SCLK/SCL DI SPI SCLK/TWI SCL 20 MISO/SDA DIO SPI MISO/TWI SDA 21 MOSI/A1 DI SPI MOSI/TWI A1 22 CSN/A0 DI SPI CSN/TWI A0 23 AOUTP AO Class-D Amplifier Output Positive 24 VSS_PA GND Class-D Ground PADDLE DGND GND Digital and Analogue Ground AIO Analogue Input / Output DIO Digital Input / Output AI Analogue Input DI Digital Input AO Analogue Output DO Digital Output NC Not Connected VDD Supply GND Ground 2019 CML Microsystems Plc 6 D/655/4 Document Outline Datasheet Front Page 1 Brief Description 2 Block Diagram 2.1 CMX655D 3 Pin List 3.1 CMX655D 4 External Components 4.1 CMX655D 4.1.1 Power Supply and Pin Decoupling 4.1.2 SPI 4.1.3 TWI 4.1.4 Speaker and Microphone 5 General Description 5.1 Power Management 5.1.1 External Supplies 5.1.2 Regulated Supplies 5.2 Device Reset 5.2.1 Power-On-Reset 5.2.2 Reset Pin 5.3 Main Clock 5.3.1 Clock Frequency 5.3.2 Clock Generation 5.3.3 PLL 5.3.4 Low Power Oscillator 5.3.5 Clock Control Registers 5.3.5.1 CLKCTRL ($03) 5.3.5.2 RDIVHI ($04) 5.3.5.3 RDIVLO ($05) 5.3.5.4 NDIVHI ($06) 5.3.5.5 NDIVLO ($07) 5.3.5.6 PLLCTRL ($08) 5.4 Microphone Interface 5.4.1 Digital Microphone Interface 5.5 Class-D Amplifier 5.5.1 Audio Outputs 5.5.2 Overload Current Protection 5.5.3 Thermal Protection 5.5.4 Clipping Detection 5.6 Audio Signal Processing 5.6.1 Record Level Control 5.6.1.1 Record Level Control Register 5.6.2 Noise Gate 5.6.2.1 Noise Gate Registers 5.6.3 Record Level Detection 5.6.3.1 Record Level Detection Registers 5.6.4 Playback Preamplifier Gain 5.6.4.1 Playback Preamplifier Gain Register 5.6.5 Playback Volume Control 5.6.5.1 Playback Volume Register 5.6.6 Automatic Level Control 5.6.6.1 ALC Registers 5.6.7 Digital Sidetone 5.6.7.1 Digital Sidetone Register 5.6.8 Voice Filters 5.6.8.1 Low Pass Filter 5.6.8.2 DC Blocking Filter 5.6.8.3 High Pass Filter 5.6.8.4 Voice Filters Registers 5.6.9 Channel Multiplexing 5.6.10 Click-and-Pop Reduction 5.6.10.1 Click-and-Pop Reduction Register 5.7 Control Interface 5.7.1 SPI Slave 5.7.2 TWI Slave 5.8 Serial Audio Interface 5.8.1 I2S Mode 5.8.2 Left-Justified Mode 5.8.3 PCM Mode 5.8.4 Audio Companding 5.8.5 Serial Audio Interface Registers 5.9 Interrupt Status and IRQN Pin 5.9.1 Interrupt Registers 5.10 System Control 5.10.1 System Control Registers 5.11 Register Address Map 6 Application Notes 6.1 Programming Examples 6.1.1 Start-up 6.1.2 Configuration 6.1.3 Enable Audio Channels 6.1.4 Shutdown 7 Performance Specification 7.1 Electrical Performance 7.1.1 Absolute Maximum Ratings 7.1.2 Operating Limits 7.1.3 Operating Characteristics 7.1.3.1 DC Parameters 7.1.3.2 AC Parameters 7.1.3.3 SPI 7.1.3.4 TWI 7.1.3.5 SAI 7.1.3.6 Digital Microphone Interface 7.2 Typical Performance Characteristics 7.2.1 THD+N vs. Level performance 7.2.2 THD+N vs. Frequency performance 7.2.3 Class D Amplifier Efficiency 7.2.4 Filter Performance Speaker Channel 7.2.5 Filter Performance Microphone Channel 7.3 Packaging 7.3.1 CMX655D End of Document cmlmicro.com CMX655D - Ultra-low Power Voice Codec - CML Micro
