Datasheet VCNL36821S (Vishay) - 2
ManufacturerVishay
DescriptionProximity Sensor With Interrupt, IRED, and I²C Interface
Pages / Page16 / 2 — VCNL36821S. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). …
File Format / SizePDF / 194 Kb
VCNL36821S. ORDERING INFORMATION ORDERING CODE. PACKAGING. VOLUME (1). REMARKS. Note. ABSOLUTE MAXIMUM RATINGS. PARAMETER
VCNL36821S ORDERING INFORMATION ORDERING CODE PACKAGING VOLUME (1) REMARKS Note ABSOLUTE MAXIMUM RATINGS PARAMETER
VCNL36821S
VCNL36821S Tape and reel MOQ: 3000 pcs, 3000 pcs/reel 2.55 mm x 2.05 mm x 1.0 mm
Note
(1) MOQ: minimum order quantity
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. MAX. UNIT
Supply voltage VDD 1.7 3.6 V Operation temperature range Tamb -40 +85 °C Storage temperature range Tstg -40 +100 °C
BASIC CHARACTERISTICS
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT
Sensor supply voltage VDD 1.7 - 3.6 V IR LED supply voltage VDD 2.5 - 3.6 V Supply current Excluding LED driving IDD 100 200 300 μA Light condition = dark; Shutdown current I V DD (SD) - 1 - μA DD = 1.8 V, Tamb = 25 °C I2C supply voltage VPULL UP 1.65 - - V I2C signal input, logic high VDD = 3.3 V VIH 1.26 - - V I2C signal input, logic low VDD = 3.3 V VIL - - 0.73 V Peak wavelength of IRED IF = 50 mA λpLED - 940 - nm IRED driving current - - 156 mA
PIN DESCRIPTIONS PIN ASSIGNMENT SYMBOL TYPE FUNCTION
1 GND - Ground 2 INT O (open drain) Interrupt pin 3 NC - Connected to GND or floating 4 LED_Cathode I Cathode (LED) connection 5 LED_Anode I Anode of LED 6 VDD - Power supply input 7 SDA I / O (open drain) I2C digital bus data input / output 8 SCL I (open drain) I2C digital bus clock input Rev. 1.1, 29-Jan-2020
2
Document Number: 80150 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
