Datasheet LPSA 300 (Vishay) - 2
ManufacturerVishay
DescriptionPower Resistor for Mounting Onto a Heatsink Thick Film Technology
Pages / Page6 / 2 — LPSA 300. MECHANICAL SPECIFICATIONS. TECHNICAL SPECIFICATIONS. Mechanical …
File Format / SizePDF / 114 Kb
LPSA 300. MECHANICAL SPECIFICATIONS. TECHNICAL SPECIFICATIONS. Mechanical Protection. Power Rating and. Resistive Element
LPSA 300 MECHANICAL SPECIFICATIONS TECHNICAL SPECIFICATIONS Mechanical Protection Power Rating and Resistive Element
LPSA 300
www.vishay.com Vishay Sfernice
Insulated case UL 94 V-0 300 W at +85 °C
Power Rating and
 bottom case temperature
Resistive Element
Thick film
Thermal Resistance
RTH (j - c): 0.112 °C/W
Substrate
Alumina
Temperature Coefficient
R  1 : ± 500 ppm/°C
End Connections
Screws M4 1 < R  10 : ± 300 ppm/°C
-55 °C / 120 °C
Standard
10 < R: ± 150 ppm/°C
Tightening Torque Connections
2 Nm
IEC 60115-1 Tightening Torque Heatsink
2 Nm
Dielectric Strength
 7 kV
IEC 60115-1, 1 min, 10 mA max.
RMS or 12 kVRMS
Maximum Torque
2.5 Nm
Lightning test 1.2/50 μs
Weight
83 g ± 10 % Until 12 kV
IEC 61000-4-5 Insulation Resistance
 104 M
Inductance
 0.1 μH
ENVIRONMENTAL SPECIFICATIONS
 100 pC/7 kV
Temperature Range
-55 °C to 120 °C
Partial Discharge
  10 pC/5 kV
(for LPSA 300 D only) Climatic Category
55/120/56 Other cases: Consult us
PERFORMANCE TESTS CONDITIONS REQUIREMENTS
IEC 60115-1
Momentary Overload
4 x Pr/10 s ± (0.5 % + 0.005 ) Umax.  UL = 5000 V IEC 60115-1
Load Life
± (0.5 % + 0.05 ) 1000 h (90/30) Pr at 85 °C AEC-Q200 rev. D conditions:
High Temperature Exposure
MIL-STD-202 method 108 ± (0.5 % + 0.005 ) 1000 h, +125 °C, unpowered AEC-Q200 rev. D conditions: JESD22 method JA-104
Temperature Cycling
± (1 % + 0.005 ) 1000 cycles, -55 °C to +125 °C dwell time -15 min AEC-Q200 rev. D conditions:
Biased Humidity
MIL-STD-202 method 103 ± (1 % + 0.005 ) 1000 h, +85 °C, 85 % RH AEC-Q200 rev. D conditions:
Operational Life
MIL-STD-202 method 108 ± (1 % + 0.005 ) 1000 h, 90/30, powered, +25 °C AEC-Q200 rev. D conditions:
ESD Human Body Model
AEC-Q200-002 ± (0.5 % + 0.005 ) 25 kVAD AEC-Q200 rev. D conditions: MIL-STD-202 method 204
Vibration
± (0.5 % + 0.005 ) 5 g for 20 min, 12 cycles test from 10 Hz to 2000 Hz AEC-Q200 rev. D conditions: MIL-STD-202 method 213
Mechanical Shock
± (0.5 % + 0.005 ) 100 g; 6 ms, 3.75 m/s 3 shocks / direction AEC-Q200 rev. D conditions:
Terminal Strength
AEC-Q200-006 ± (0.25 % + 0.01 ) 2.27 kg, 60 s Revision: 21-Nov-2019
2
Document Number: 50076 For technical questions, contact: sferfixedresistors@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
