LPSA 600 www.vishay.com Vishay Sfernice Power Resistor for Mounting Onto a HeatsinkThick Film TechnologyFEATURES • AEC-Q200 qualified • Compliant with requirement #26 of NF-EN45545-2 • High power 600 W at 85 °C bottom case temperature • Wide resistance range: 0.3 to 900 k E24 series • Non inductive ADDITIONAL RESOURCES • Easy mounting • Low thermal radiation of the case D 33 D 3D Models • Material categorization: for definitions of compliance please see www.vishay.com/doc?99912 LPSA is a fully AEC-Q200 qualified high power resistor. Its high power / energy capability makes it a perfect fit for automotive precharge and discharge applications requiring high levels of performance. DIMENSIONS in millimeters 25.8 ± 1LPSA 600 6K8 5 %25.2V221.26015.2± 0.53664.72 x M4 useful depth: 82 x Ø 4.2Ø 2013.63457Note • Tolerances unless stated: ± 0.2 mm STANDARD ELECTRICAL SPECIFICATIONSRESISTANCERATED POWERLIMITING ELEMENTTEMPERATURECRITICALTOLERANCEMODELRANGEP85 °CVOLTAGE ULCOEFFICIENTRESISTANCE± %WV± ppm/°C() LPSA 600 0.3 to 900K 600 5K 1, 2, 5, 10 150, 300, 500 41.66K Revision: 21-Nov-2019 1 Document Number: 50077 For technical questions, contact: sferfixedresistors@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
