Datasheet KW CULPM1.TG - OSLON Boost HX (OSRAM)
ManufacturerOSRAM
DescriptionOSLON Boost HX LED makes use of the high current capability of the latest chip generation in a thermal optimized package
Pages / Page25 / 1 — Produktdatenblatt. |. Version. 1.1. www.osram-os.com. KW. CULPM1.TG. KW. …
Produktdatenblatt. |. Version. 1.1. www.osram-os.com. KW. CULPM1.TG. KW. CULPM1.TG. OSLON®. Boost. HX. OSLON. Boost. HX. makes. use. of. the. high. current
Datasheet KW CULPM1.TG - OSLON Boost HX OSRAM
Produktdatenblatt | Version 1.1 www.osram-os.com KW CULPM1.TG KW CULPM1.TG OSLON® Boost HX OSLON Boost HX makes use of the high current capability of the latest chip generation in a thermal optimized package. The LED is characterized by a high luminance from up to 200 cd/mm² and high luminous flux. Therefore this LED is ideally suited as a powerful light source for high-definition MEMS AFS. Applications
Headlamps, LED & Laser & Night Vision Features:
Package: Ceramic package
Chip technology: UX:3
Typ. Radiation: 120° (Lambertian emitter)
Color: Cx = 0.32, Cy = 0.33 acc. to CIE 1931 (● white)
Corrosion Robustness Class: 3A
Qualifications: The product qualification test plan is based on the guidelines of IEC60810, Lamps for road vehicles – Performance requirements – Requirements and test conditions for LED packages.
ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B) 1 Version 1.8 | 2019-08-06
