Datasheet 10A05 - 10A10 (Rectron Semiconductor)
ManufacturerRectron Semiconductor
DescriptionStandard Rectifier
Pages / Page5 / 1 — 10A05. THRU. 10A10. SILICON RECTIFIER. VOLTAGE RANGE 1000 Volts CURRENT …
File Format / SizePDF / 237 Kb
10A05. THRU. 10A10. SILICON RECTIFIER. VOLTAGE RANGE 1000 Volts CURRENT 10 Amperes. FEATURES. R-6. MECHANICAL DATA
Datasheet 10A05 - 10A10 Rectron Semiconductor
10A05 THRU 10A10 SILICON RECTIFIER VOLTAGE RANGE 1000 Volts CURRENT 10 Amperes FEATURES
* High surge current capability * Low leakage * Low forward voltage drop * High current capability * Low lost
R-6 MECHANICAL DATA
* Case: Molded plastic black body * Epoxy: Device has UL flammability classification 94V-O .052 (1.3) DIA. * Lead: MIL-STD-202E method 208C guaranteed 1.0 (25.4) .048 (1.2) MIN. * Mounting position: Any * Weight: 2.08 gram .360 (9.1) .340 (8.6) .360 (9.1) DIA. .340 (8.6)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
1.0 (25.4) MIN. Ratings at 25 oC ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Dimensions in inches and (millimeters)
MAXIMUM RATINGS
(@ TA=25 OC unless otherwise noted) RATINGS SYMBOL 10A05 10A1 10A2 10A4 10A6 10A8 10A10 UNITS Maximum Recurrent Peak Reverse Voltage VRRM 1000 Volts Maximum RMS Voltage VRMS 700 Volts Maximum DC Blocking Voltage VDC 1000 Volts Maximum Average Forward Rectified Current at TA = 50oC IO 10 Amps Peak Forward Surge Current IFM(surge): 8.3 ms single half sine-wave IFSM 400 Amps superimposed on rated load (JEDEC method) Typical Current Squared Time I2T 664 A2S Typical Thermal Resistance (Note 3) Rθ 0 JA 20 C/W Typical Thermal Resistance (Note 4) Rθ 0 JL 4 C/W 0 Typical Thermal Resistance (Note 5) RθJC 6 C/W Typical Junction Capacitance (Note 1) CJ 135 pF Operating and Storage Temperature Range T 0 J, TSTG -55 to + 150 C
(@TA=25 OC unless otherwise noted) CHARACTERISTICS SYMBOL 10A05 10A1 10A2 10A4 10A6 10A8 10A10 U N I T S Maximum Forward Voltage at 10A DC VF 1.1 Volts Maximum DC Average Reverse Current at @TA = 25oC 5 uAmps Rated DC Blocking Voltage @TA = 150oC 2 mAmps IR Maximum Full Load Reverse Current Average Full Cycle 50 uAmps .375" (9.5mm) Lead Length at TL=75OC NOTES : 1. Measured at 1.0 MHz and applied average voltage of 4.0VDC 2019-02 REV:B 2. “ ROHS compliant”. 3. Thernal Resistance: At 9.5mm lead lengths,PCB mounted. 4. Thernal Resistance Junction to lead 5. Thernal Resistance Junction to dice
