Datasheet FDA901 (STMicroelectronics) - 6
Description4 x 50 W class-D digital input power amplifier with load current monitoring and low voltage operation
Pages / Page17 / 6 — FDA901. Pins description. Pin. Function. DB3856. Rev 1. page 6/17
File Format / SizePDF / 311 Kb
FDA901 Pins description Pin Function DB3856 Rev 1 page 6/17
FDA901 Pins description N# Pin Function
52 I2Cclk I2C Clock (SCL) 53 I2Cdata I2C Data (SDA) 54 I2Sdata2 I2S/TDM Data input 2 55 I2Sdata1 I2S/TDM Data input 1 56 I2Sclk I2S/TDM Clock input 57 I2Sws I2S/TDM Sinc input 58 Agnd Analog ground 59 AVdd Analog supply 60 AGSVR Negative Analog Supply V(SVR)-2.5V (Internally generated) 61 A5VSVR Positive Analog Supply V(SVR)+2.5V (Internally generated) 62 SVR Supply Voltage Ripple Rejection Capacitor 63 HWMute Hardware mute pin 64 GND2+ Channel 2, half bridge plus, Power Ground
DB3856
Rev 1 page 6/17
Document Outline 1 Block diagram and pins description 1.1 Block diagram 1.2 Pins description 2 Electrical specifications 2.1 Absolute maximum ratings 2.2 Thermal data 3 General information 3.1 New feedback topology 3.2 LC filter design 3.3 Load possibilities 4 Package information 4.1 LQFP64 (10x10x1.4 mm exp. pad up) package information 4.2 LQFP64 (10x10x1.4 mm exp. pad up) marking information Revision history
