Datasheet TMP05, TMP06 (Analog Devices) - 10
Description±0.5°C Accurate PWM Temperature Sensor in 5-Lead SC-70
Pages / Page28 / 10 — TMP05/TMP06. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. VDD = 3.3V …
RevisionC
File Format / SizePDF / 473 Kb
TMP05/TMP06. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. VDD = 3.3V AND 5V. CLOAD = 100pF. (H Y. E (V). UT P UT. 1V/DIV. 100ns/DIV
TMP05/TMP06 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS VDD = 3.3V AND 5V CLOAD = 100pF (H Y E (V) UT P UT 1V/DIV 100ns/DIV
TMP05/TMP06 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 14 VDD = 3.3V AND 5V CLOAD = 100pF 12 z) 10 (H Y NC 8 E (V) UE G Q 0 A RE LT 6 F VO UT P UT 4 O 2 1V/DIV 100ns/DIV OUT PIN LOADED WITH 10kΩ RESISTOR 0
023
–40 –20 0 20 40 60 80 100 120 140 0
020
TIME (ns)
03340-
TEMPERATURE (°C)
03340- Figure 6. PWM Output Frequency vs. Temperature Figure 9. TMP05 Output Rise Time at 25°C
10.14 10.12 10.10 V z) 10.08 DD = 3.3V AND 5V CLOAD = 100pF (H Y 10.06 NC 10.04 E (V) UE G Q 0 10.02 A RE LT F 10.00 VO UT P 9.98 UT O 9.96 9.94 9.92 1V/DIV 100ns/DIV OUT PIN LOADED WITH 10kΩ RESISTOR 9.90
024
3.0 3.3 3.6 3.9 4.2 4.5 4.8 5.1 5.4 0
041
TIME (ns)
03340-
SUPPLY VOLTAGE (V)
03340- Figure 7. PWM Output Frequency vs. Supply Voltage Figure 10. TMP05 Output Fall Time at 25°C
120 100 TL TIME VDD = 3.3V AND 5V RPULLUP = 1kΩ R 80 LOAD = 10kΩ CLOAD = 100pF E (V) ms) G ( 0 60 A E LT TIM VO 40 TH TIME 20 1V/DIV 100ns/DIV OUT PIN LOADED WITH 10kΩ RESISTOR 0 0
025
–40 –20 0 20 30 50 70 90 110 130 150
022
TIME (ns)
03340-
TEMPERATURE (°C)
03340- Figure 8. T Figure 11. TMP06 Output Fall Time at 25°C H and TL Times vs. Temperature Rev. C | Page 10 of 28 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications TMP05A/TMP06A Specifications TMP05B/TMP06B Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Circuit Information Converter Details Functional Description Operating Modes Continuously Converting Mode One Shot Mode Conversion Rate Daisy-Chain Mode TMP05 Output TMP06 Output Application Hints Thermal Response Time Self-Heating Effects Supply Decoupling Layout Considerations Temperature Monitoring Daisy-Chain Application TMP05 Program Code Example 1 Continuously Converting Application TMP05 Program Code Example 2 Outline Dimensions Ordering Guide
