Datasheet ADT7516, ADT7517, ADT7519 (Analog Devices) - 8
Description | SPI-/I2C-Compatible, Temperature Sensor, 4-Channel ADC and Quad Voltage Output |
Pages / Page | 44 / 8 — ADT7516/ADT7517/ADT7519. FUNCTIONAL BLOCK DIAGRAM. INTERNAL. TEMPERATURE. … |
Revision | B |
File Format / Size | PDF / 3.3 Mb |
ADT7516/ADT7517/ADT7519. FUNCTIONAL BLOCK DIAGRAM. INTERNAL. TEMPERATURE. ON-CHIP. VALUE REGISTER. ADDRESS POINTER. REGISTER. SENSOR
ADT7516/ADT7517/ADT7519 FUNCTIONAL BLOCK DIAGRAM INTERNAL TEMPERATURE ADT7516/ADT7517/ADT7519 ON-CHIP VALUE REGISTER ADDRESS POINTER TEMPERATURE REGISTER SENSOR EXTERNAL THIGH LIMIT TEMPERATURE REGISTERS VALUE REGISTER TLOW LIMIT UX UX REGISTERS D+/AIN1 7 DAC A STRING M M 2 VOUT-A L LIMIT L VCC LIMIT REGISTERS DAC A D–/AIN2 8 REGISTERS A-TO-D ITA COMPARATOR ITA ANALOG G G LDAC/AIN3 9 MUX CONVERTER AIN DI DI HIGH LIMIT DAC B STRING REGISTERS V REGISTERS DAC B 1 OUT-B AIN4 14 AINLOW LIMIT V REGISTERS DD DAC C STRING VALUE REGISTER CONTROL CONFIG. 1 V REGISTERS DAC C 16 OUT-C REGISTER AIN1 V VALUE REGISTER CONTROL CONFIG. 2 DD REGISTER DAC D STRING SENSOR V AIN2 REGISTERS DAC D 15 OUT-D VALUE REGISTER CONTROL CONFIG. 3 REGISTER AIN3 GAIN POWER- VALUE REGISTER DAC CONFIGURATION REGISTERS SELECT DOWN AIN4 LOGIC LOGIC LDAC CONFIGURATION VALUE REGISTER REGISTERS STATUS INTERRUPT MASK 10 INT/INT REGISTERS REGISTERS INTERNAL SPI/SMBus INTERFACE REFERENCE
1 00 3- 88
6 5 4 13 12 11 9 3
02
V GND CS SCL SDA DD ADD LDAC/AIN3 VREF-IN
Figure 6. Functional Block Diagram for the ADT7516/ADT7517/ADT7519 Rev. B | Page 8 of 44 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DAC AC CHARACTERISTICS TIMING DIAGRAMS FUNCTIONAL BLOCK DIAGRAM ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTIONAL DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION POWER-UP CALIBRATION CONVERSION SPEED FUNCTION DESCRIPTION—VOLTAGE OUTPUT Digital-to-Analog Converters Digital-to-Analog Section Resistor String DAC Reference Inputs Output Amplifier Thermal Voltage Output FUNCTIONAL DESCRIPTION—ANALOG INPUTS Single-Ended Inputs Converter Operation ADC TRANSFER FUNCTION Analog Input ESD Protection AIN Interrupts FUNCTIONAL DESCRIPTION—MEASUREMENT Temperature Sensor VDD Monitoring On-Chip Reference Round Robin Measurement Single Channel Measurement Temperature Measurement Method Layout Considerations Interrupts ADT7516/ADT7517/ADT7519 REGISTERS Interrupt Status 1 Register (Read-Only) [Address 0x00] Interrupt Status 2 Register (Read-Only) [Address = 0x01] Internal Temperature Value/VDD Value Register LSBs (Read-Only) [Address = 0x03] External Temperature Value and Analog Input 1 to Analog Input 4 Register LSBs (Read-Only) [Address = 0x04] VDD Value Register MSBs (Read-Only) [Address = 0x06] Internal Temperature Value Register MSBs (Read-Only) [Address = 0x07] External Temperature Value or Analog Input AIN1 Register MSBs (Read-Only) [Address = 0x08] AIN2 Register MSBs (Read) [Address = 0x09] AIN3 Register MSBs (Read) [Address = 0x0A] AIN4 Register MSBs (Read) [Address = 0x0B] DAC A Register LSBs (Read/Write) [Address = 0x10] DAC A Register MSBs (Read/Write) [Address = 0x11] DAC B Register LSBs (Read/Write) [Address = 0x12] DAC B Register MSBs (Read/Write) [Address = 0x13] DAC C Register LSBs (Read/Write) [Address = 0x14] DAC C Register MSBs (Read/Write) [Address = 0x15] DAC D Register LSBs (Read/Write) [Address = 0x16] DAC D Register MSBs (Read/Write) [Address = 0x17] Control Configuration 1 Register (Read/Write) [Address = 0x18] Control Configuration 2 Register (Read/Write) [Address = 0x19] Control Configuration 3 Register (Read/Write) [Address = 0x1A] DAC Configuration Register (Read/Write) [Address = 0x1B] LDAC Configuration Register (Write-Only)[Address = 0x1C] Interrupt Mask 1 Register (Read/Write) [Address = 0x1D] Interrupt Mask 2 Register (Read/Write) [Address = 0x1E] Internal Temperature Offset Register (Read/Write) [Address = 0x1F] External Temperature Offset Register (Read/Write) [Address = 0x20] Internal Analog Temperature Offset Register (Read/Write) [Address = 0x21] External Analog Temperature Offset Register (Read/Write) [Address = 0x22] VDD VHIGH Limit Register (Read/Write) [Address = 0x23] VDD VLOW Limit Register (Read/Write) [Address = 0x24] Internal THIGH Limit Register (Read/Write) [Address = 0x25] Internal TLOW Limit Register (Read/Write) [Address = 0x26] External THIGH/AIN1 VHIGH Limit Register (Read/Write) [Address = 0x27] External TLOW/AIN1 VLOW Limit Register (Read/Write) [Address = 0x28] AIN2 VHIGH Limit Register (Read/Write) [Address = 0x2B] AIN2 VLOW Limit Register (Read/Write) [Address = 0x2C] AIN3 VHIGH Limit Register (Read/Write) [Address = 0x2D] AIN3 VLOW Limit Register (Read/Write) [Address = 0x2E] AIN4 VHIGH Limit Register (Read/Write) [Address = 0x2F] AIN4 VLOW Limit Register (Read/Write) [Address = 0x30] Device ID Register (Read-Only) [Address = 0x4D] Manufacturer’s ID Register (Read-Only) [Address = 0x4E] Silicon Revision Register (Read-Only) [Address = 0x4F] SPI Lock Status Register (Read-Only) [Address = 0x7F] SERIAL INTERFACE Serial Interface Selection I2C Serial Interface Writing to the ADT7516/ADT7517/ADT7519 Writing to the Address Pointer Register for a Subsequent Read Writing Data to a Register Reading Data from the ADT7516/ADT7517/ADT7519 SPI Serial Interface Write Operation Read Operation SMBus/SPI INT/ SMBUS ALERT RESPONSE OUTLINE DIMENSIONS ORDERING GUIDE
