Datasheet ADT7517-KGD (Analog Devices) - 6
DescriptionSPI-/I2C-Compatible, Temperature Sensor, 4-Channel ADC and Quad Voltage Output
Pages / Page11 / 6 — ADT7517-KGD. Known Good Die. DAC AC CHARACTERISTICS. Table 2. Parameter1. …
File Format / SizePDF / 243 Kb
ADT7517-KGD. Known Good Die. DAC AC CHARACTERISTICS. Table 2. Parameter1. Min. Typ2. Max. Unit. Test Conditions/Comments
ADT7517-KGD Known Good Die DAC AC CHARACTERISTICS Table 2 Parameter1 Min Typ2 Max Unit Test Conditions/Comments
VDD = 2.7 V to 5.5 V, RL = 4.7 kΩ to GND, CL = 200 pF to GND, 4.7 kΩ to VDD, all specifications TMIN to TMAX, unless otherwise noted.
Table 2. Parameter1 Min Typ2 Max Unit Test Conditions/Comments
Output Voltage Settling Time 7 9 µs VREF = VDD = 5 V, 1/4 scale to 3/4 scale change (0x100 to 0x300) Slew Rate 0.7 V/µs Major Code Change Glitch Energy 12 nV-sec 1 LSB change around major carry Digital Feedthrough 0.5 nV-sec Digital Crosstalk 1 nV-sec Analog Crosstalk 0.5 nV-sec DAC-to-DAC Crosstalk 3 nV-sec Multiplying Bandwidth 200 kHz VREF = 2 V ± 0.1 V p-p Total Harmonic Distortion −70 dB VREF = 2.5 V ± 0.1 V p-p; frequency = 10 kHz 1 Guaranteed by design and characterization; not production tested. 2 At 25°C. Rev. A | Page 6 of 11 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DAC AC CHARACTERISTICS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
