Datasheet ADT7517-KGD (Analog Devices) - 10
DescriptionSPI-/I2C-Compatible, Temperature Sensor, 4-Channel ADC and Quad Voltage Output
Pages / Page11 / 10 — ADT7517-KGD. Known Good Die. X-Axis. Y-Axis. Pad No. (µm). (µm). …
File Format / SizePDF / 243 Kb
ADT7517-KGD. Known Good Die. X-Axis. Y-Axis. Pad No. (µm). (µm). Mnemonic. Description
ADT7517-KGD Known Good Die X-Axis Y-Axis Pad No (µm) (µm) Mnemonic Description
ADT7517-KGD Known Good Die X-Axis Y-Axis Pad No. (µm) (µm) Mnemonic Description
13 +764 −271 SDA/DIN I2C Serial Data Input/Output (SDA). I2C serial data to be loaded into the registers of the part and read from these registers is provided on this pad. This open-drain configuration requires a pull-up resistor. SPI Serial Data Input (DIN). Serial data to be loaded into the registers of the part is provided on this pad. Data is clocked into a register on the rising edge of SCLK. This open-drain configuration requires a pull-up resistor. 14 +764 −117 SCL/SCLK I2C Serial Clock Input (SCL)/SPI Serial Clock Input (SCLK). This pad is the clock input for the serial port. The serial clock is used to clock data out of any register of the ADT7517-KGD and also to clock data into any register that can be written to. This open-drain configuration requires a pull-up resistor. 15 +764 +1043 AIN4 Analog Input. Single-ended analog input channel. Input range is 0 V to 2.28 V or 0 V to VDD. 16 +338 +1092 VOUT-D Buffered Analog Output Voltage from DAC D. The output amplifier has rail-to-rail operation. 17 −83 +1092 VOUT-C Buffered Analog Output Voltage from DAC C. The output amplifier has rail-to-rail operation. 18 −285 +1092 VOUT-B Buffered Analog Output Voltage from DAC B. The output amplifier has rail-to-rail operation. 19 −503 +1092 VOUT-A Buffered Analog Output Voltage from DAC A. The output amplifier has rail-to-rail operation. Rev. A | Page 10 of 11 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DAC AC CHARACTERISTICS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
