Datasheet IX4351NE (IXYS) - 3
ManufacturerIXYS
Description9A Low Side SiC MOSFET & IGBT Driver
Pages / Page12 / 3 — IX4351NE. Specifications. 1.1 Package Pinout. 1.2 Pin Description. Pin#. …
File Format / SizePDF / 334 Kb
IX4351NE. Specifications. 1.1 Package Pinout. 1.2 Pin Description. Pin#. Name. Description. www.ixysic.com
IX4351NE Specifications 1.1 Package Pinout 1.2 Pin Description Pin# Name Description www.ixysic.com
I
IX4351NE
NTEGRATED CIRCUITS DIVISION
1 Specifications 1.1 Package Pinout
IX4351 OUTSRC 1 16 OUTSNK V 2 15 DD VSS V 3 14 DD OUTSOFT DESAT 4 13 INSOFT FAULT 5 12 CAP IN 6 11 GND COM 7 10 VSS VREG 8 9 SET
1 OUTSRC Gate driver source output 2 VDD Positive supply voltage for gate driver outputs and logic circuitry 3 VDD Positive supply voltage for gate driver outputs and logic circuitry 4 DESAT Sense input for the desaturation detection comparator 5 FAULT Open-Drain Fault status output 6 IN Logic input 7 COM Common ground connection 8 VREG 4.6V regulator output 9 SET Negative bias voltage set input 10 VSS Negative drive voltage supply 11 GND Charge pump ground connection 12 CAP Flying charge pump capacitor connection 13 INSOFT Soft shutdown comparator input 14 OUTSOFT Soft shutdown sink driver output 15 VSS Negative drive voltage supply 16 OUTSNK Gate driver sink output R02
www.ixysic.com
3 Document Outline Features Applications Description Ordering Information 1 Specifications 1.1 Package Pinout 1.2 Pin Description 1.3 Absolute Maximum Ratings 1.4 Recommended Operating Conditions 1.5 Electrical Characteristics 1.6 Thermal Characteristics 2 Performance Data 3 Performance Data (Cont.) 4 Functional Description 4.1 Logic Input (IN) 4.2 Gate Drive Outputs (OUTSRC and OUTSNK) 4.3 Internal 4.6V Regulator (VREG) 4.4 Negative VSS Charge Pump Regulator 4.5 Desaturation Detection and Protection 4.6 Thermal Shutdown 4.7 FAULT Output 5 Manufacturing Information 5.1 Moisture Sensitivity 5.2 ESD Sensitivity 5.3 Soldering Profile 5.4 Board Wash 5.5 Mechanical Dimensions
