Datasheet LUXEON IR Domed (Lumileds) - 4
Manufacturer | Lumileds |
Description | High power infrared emitters with engineered primary optics for high efficiency and beam control |
Pages / Page | 20 / 4 — Performance Characteristics |
File Format / Size | PDF / 2.4 Mb |
Environmental Compliance Lumileds LLC is committed to providing environmentally friendly products to the solid-state lighting market. LUXEON IR Domed Line is compliant to the European Union directives on the restriction of hazardous substances in electronic equipment, namely the RoHS Directive 2011/65/EU and REACH Regulation (EC) 1907/2006. Lumileds LLC will not intentionally add the following restricted materials to its products: lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) or polybrominated diphenyl ethers (PBDE).
Product Selection Guide
Table 1 . Product performance and optical characteristics of LUXEON IR Domed Line at 1000mA, T =25°C . j Peak tyPIcaL radIOmetrIc POWer [2] tyPIcaL radIant maX drIVe WaVeLenGtH [1] fWHm Beam (mW) IntensIty cUrrent Part nUmBer (nm) anGLe (°) (mW/sr) (dc)/(PULse) mInImUm tyPIcaL
850 150 1000 1350 335 1A/3A L1I0-0850150000000 850 90 1000 1350 750 1A/3A L1I0-0850090000000 850 60 1000 1350 1150 1A/3A L1I0-0850060000000 850 95 x 58 1000 1350 650 1A/3A L1I0-0850955800000 940 150 1100 1450 350 1A/3A L1I0-0940150000000 940 90 1100 1450 780 1A/3A L1I0-0940090000000 940 60 1100 1450 1190 1A/3A L1I0-0940060000000 940 95 x 58 1100 1450 700 1A/3A L1I0-0940955800000 850 150 1050 1350 335 1.5A/5A L1I0-0850150200000 850 90 1050 1350 750 1.5A/5A L1I0-0850090200000 850 60 1050 1350 1150 1.5A/5A L1I0-0850060200000 850 50 1050 1350 1255 1.5A/5A L1I0-0850050200000 940 150 1125 1450 350 1.5A/5A L1I0-0940150200000 940 90 1125 1450 780 1.5A/5A L1I0-0940090200000 940 60 1125 1450 1190 1.5A/5A L1I0-0940060200000 940 50 1125 1450 1335 1.5A/5A L1I0-0940050200000 Notes for Table 1: 1. Lumileds maintains a tolerance of ±2nm on peak wavelength measurements. 2. Lumileds maintains a tolerance of ±7% on radiometric power measurements. Optical Characteristics
Table 2 . Optical characteristics for LUXEON IR Domed Line at 1000mA, T =25°C . j Peak WaVeLenGtH [1] (nm) tyPIcaL tyPIcaL temPeratUre Part nUmBer sPectrUm cOeffIcIent Of Peak mInImUm tyPIcaL maXImUm fWHm (nm) WaVeLenGtH (nm/°c)
L1I0-0850xxxx00000 835 850 870 35 0.26 L1I0-0940xxxx00000 925 940 955 50 0.29 Notes for Table 2: 1. Lumileds maintains a tolerance of ±2nm on peak wavelength measurements. DS191 LUXEON IR Domed Line Product Datasheet 20200403 ©2020 Lumileds Holding B.V. All rights reserved. 3 Document Outline General Product Information Product Test Conditions Part Number Nomenclature Radiometric Power Maintenance Environmental Compliance Performance Characteristics Product Selection Guide Optical Characteristics Electrical and Thermal Characteristics Absolute Maximum Ratings Characteristic Curves Spectral Power Distribution Characteristics Light Output Characteristics Forward Current Characteristics Wavelength Shift Characteristics Radiation Pattern Characteristics Permissible Pulse Handling Characteristics Product Bin and Labeling Definitions Decoding Product Bin Labeling Radiometric Power Bins Peak Wavelength Bins Forward Voltage Bins Mechanical Dimensions Reflow Soldering Guidelines JEDEC Moisture Sensitivity Solder Pad Design Packaging Information Pocket Tape Dimensions Reel Dimensions
