Datasheet LUXEON IR Domed (Lumileds) - 8
Manufacturer | Lumileds |
Description | High power infrared emitters with engineered primary optics for high efficiency and beam control |
Pages / Page | 20 / 8 — Figure 5. Typical peak wavelength shift vs. case temperature for LUXEON … |
File Format / Size | PDF / 2.4 Mb |
Figure 5. Typical peak wavelength shift vs. case temperature for LUXEON IR Domed Line at 1000mA
Wavelength Shift Characteristics
Figure 5. Typical peak wavelength shift vs. case temperature for LUXEON IR Domed Line at 1000mA .
Radiation Pattern Characteristics
Figure 6a . Typical radiation pattern for LUXEON IR Domed L1I0-0xxxxxx200000 at 1000mA, T =25°C . j
DS191 LUXEON IR Domed Line Product Datasheet 20200403 ©2020 Lumileds Holding B.V. All rights reserved. 7 Document Outline General Product Information Product Test Conditions Part Number Nomenclature Radiometric Power Maintenance Environmental Compliance Performance Characteristics Product Selection Guide Optical Characteristics Electrical and Thermal Characteristics Absolute Maximum Ratings Characteristic Curves Spectral Power Distribution Characteristics Light Output Characteristics Forward Current Characteristics Wavelength Shift Characteristics Radiation Pattern Characteristics Permissible Pulse Handling Characteristics Product Bin and Labeling Definitions Decoding Product Bin Labeling Radiometric Power Bins Peak Wavelength Bins Forward Voltage Bins Mechanical Dimensions Reflow Soldering Guidelines JEDEC Moisture Sensitivity Solder Pad Design Packaging Information Pocket Tape Dimensions Reel Dimensions
