Datasheet LT3092 (Analog Devices) - 2
Description200mA 2-Terminal Programmable Current Source
Pages / Page24 / 2 — absoluTe MaxiMuM raTings (Note 1) All Voltages Relative to VOUT. pin …
File Format / SizePDF / 460 Kb
absoluTe MaxiMuM raTings (Note 1) All Voltages Relative to VOUT. pin conFiguraTion
absoluTe MaxiMuM raTings (Note 1) All Voltages Relative to VOUT pin conFiguraTion
LT3092
IN Pin Voltage Relative to SET, OUT ..±40V Operating Junction Temperature Range (Notes 2, 8) SET Pin Current (Note 6) ... ±15mA E, I Grades ... –40°C to 125°C SET Pin Voltage (Relative to OUT, Note 6) .. ±10V MP Grade ... –55°C to 125°C Output Short-Circuit Duration .. Indefinite Storage Temperature Range .. –65°C to 150°C Lead Temperature (ST, TS8 Packages Only) Soldering, 10 sec ..300°C
pin conFiguraTion
TOP VIEW TOP VIEW OUT 1 8 IN 3 IN TOP VIEW OUT 2 7 IN NC 1 8 IN 9 TAB IS OUT 2 OUT NC 3 6 NC OUT 2 7 IN OUT 3 6 NC SET 4 5 NC 1 SET OUT 4 5 SET ST PACKAGE TS8 PACKAGE DD PACKAGE 3-LEAD PLASTIC SOT-223 8-LEAD PLASTIC TSOT-23 8-LEAD (3mm × 3mm) PLASTIC DFN T T T JMAX = 125°C, θJA = 24°C/W, θJC = 15°C/W JMAX = 125°C, θJA = 57°C/W, θJC = 15°C/W JMAX = 125°C, θJA = 28°C/W, θJC = 10°C/W TAB IS OUT, MUST BE SOLDERED TO OUT ON THE PCB. EXPOSED PAD (PIN 9) IS OUT, MUST BE SOLDERED TO OUT SEE THE APPLICATIONS INFORMATION SECTION. ON THE PCB. SEE THE APPLICATIONS INFORMATION SECTION. 3092fc 2 For more information www.linear.com/LT3092 Document Outline Description Typical Application Absolute Maximum Ratings Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Applications Information Package Description Related Parts
