Datasheet ADN8810 (Analog Devices)
Description | 12-Bit High Output Current Source |
Pages / Page | 14 / 1 — 12-Bit High Output Current Source. Data Sheet. ADN8810. FEATURES. … |
Revision | C |
File Format / Size | PDF / 443 Kb |
12-Bit High Output Current Source. Data Sheet. ADN8810. FEATURES. FUNCTIONAL BLOCK DIAGRAM. High precision 12-bit current source
12-Bit High Output Current Source Data Sheet ADN8810 FEATURES FUNCTIONAL BLOCK DIAGRAM High precision 12-bit current source 5V 5V 3.3V Low noise Long term stability ENCOMP DVDD AVDD PVDD Current output from 0 mA to 300 mA RESET RESET FB Output fault indication 4.096V VREF R Low drift SN CS 1.6 Programmable maximum current ADN8810 IOUT SERIAL INTERFACE SCLK R 24-lead, 4 mm × 4 mm LFCSP SN D1 SDI 1.6 3-wire serial interface ADDRESS ADDR0-2 RSN 3 APPLICATIONS FAULT SB AVSS DVSS DGND Tunable laser current source
1 00
Programmable high output current source
0-
FAULT SB
95-
INDICATION Automatic test equipment
031 Figure 1.
GENERAL DESCRIPTION
The ADN8810 is a 12-bit current source with an adjustable full- Noise and digital feedthrough are kept low to ensure low jitter scale output current of up to 300 mA. The full-scale output current operation for laser diode applications. Full-scale and scaled is set with two external sense resistors. The output compliance output currents are given in Equation 1 and Equation 2, voltage is 2.5 V, even at output currents up to 300 mA. respectively. The device is particularly suited for tunable laser control and VREF I (1) can drive tunable laser front mirror, back mirror, phase, gain, FS 10 RSN and amplification sections. A host CPU or microcontroller controls the operation of the ADN8810 over a 3-wire serial V 1 R REF SN I Code 0.1 (2) peripheral interface (SPI). The 3-bit address allows up to eight OUT 4096 R 15 k SN devices to be independently controlled while attached to the same SPI bus. The ADN8810 is guaranteed with ±4 LSB integral nonlinearity (INL) and ±0.75 LSB differential nonlinearity (DNL).
Rev. C Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2004–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY FUNCTIONAL DESCRIPTION SETTING FULL-SCALE OUTPUT CURRENT POWER SUPPLIES SERIAL DATA INTERFACE STANDBY AND RESET MODES POWER DISSIPATION USING MULTIPLE ADN8810 DEVICES FOR ADDITIONAL OUTPUT CURRENT ADDING DITHER TO THE OUTPUT CURRENT DRIVING COMMON-ANODE LASER DIODES PCB LAYOUT RECOMMENDATIONS SUGGESTED PAD LAYOUT FOR CP-24 PACKAGE OUTLINE DIMENSIONS ORDERING GUIDE
