Datasheet SMBJ12(C)AQ – SMBJ100(C)AQ (Diodes)
ManufacturerDiodes
Description600W Surface Mount Automotive Transient Voltage Suppressor
Pages / Page6 / 1 — SMBJ12(C)AQ – SMBJ100(C)AQ. 600W SURFACE MOUNT AUTOMOTIVE TRANSIENT …
File Format / SizePDF / 356 Kb
SMBJ12(C)AQ – SMBJ100(C)AQ. 600W SURFACE MOUNT AUTOMOTIVE TRANSIENT VOLTAGE SUPPRESSOR. Product Summary
Datasheet SMBJ12(C)AQ – SMBJ100(C)AQ Diodes
SMBJ12(C)AQ – SMBJ100(C)AQ 600W SURFACE MOUNT AUTOMOTIVE TRANSIENT VOLTAGE SUPPRESSOR Product Summary
(@TA = +25°C)
Features and Benefits PPK IFSM VRWM PM(AV)
• 600W Peak Pulse Power Dissipation 600W 100A 12V to 100V 5W • 12V to 100V Standoff Voltages • Glass Passivated Die Construction • Unidirectional and Bidirectional Versions Available • Excellent Clamping Capability •
Lead-Free Finish; RoHS Compliant (Notes 1 & 2)
Halogen and Antimony Free. “Green” Device (Note 3)
The SMBJ12(C)AQ – SMBJ100(C)AQ is suitable for Description and Applications automotive applications requiring specific change control; this part is AEC-Q101 qualified, PPAP capable, and
Suitable to protect sensitive automotive circuits against surges defined
manufactured in IATF 16949 certified facilities.
in ISO7637-2 and against electrostatic discharges according to
https:/ www.diodes.com/quality/product-definitions/
ISO10605. Compliance with the following standards:
Mechanical Data
• ISO10605, C = 150pF, R = 330Ω: • Case: SMB  30kV (Air Discharge) • Case Material: Molded Plastic.  30kV (Contact Discharge) UL Flammability Classification Rating 94V-0 • ISO7637-2 (Note 5) • Moisture Sensitivity: Level 1 per J-STD-020  Pulse 1: Vs = -150V • Terminals: Lead Free Plating (Matte Tin Finish). Solderable per  Pulse 2a: Vs = +112V MIL-STD-202, Method 208  Pulse 3a: Vs = -220V • Weight: 0.1 grams (Approximate)  Pulse 3b: Vs = +150V SMB Top View Bottom View
Ordering Information
(Note 4)
Part Number Qualification Case Packaging
SMBJXXX(C)AQ-13-F Automotive SMB 3000/Tape & Reel *X = Device Voltage, e.g., SMBJ14AQ-13-F. Notes: 1. EU Directive 2002/95/EC (RoHS), 2011/65/EU (RoHS 2) & 2015/863/EU (RoHS 3) compliant. Al applicable RoHS exemptions applied. 2. See https://www.diodes.com/quality/lead-free/ for more information about Diodes Incorporated’s definitions of Halogen- and Antimony-free, "Green" and Lead-free. 3. Halogen- and Antimony-free "Green” products are defined as those which contain <900ppm bromine, <900ppm chlorine (<1500ppm total Br + Cl) and <1000ppm antimony compounds. 4. For packaging details, go to our website at https://www.diodes.com/design/support/packaging/diodes-packaging/. 5. Not applicable to parts with stand-off voltage lower than the average battery voltage (13.5V).
Marking Information
Bidirectional Device Cathode Band for Unidirectional Device xx = Product Type Marking Code (See Page 3)
YWW
= Manufacturers’ Marking YWW = Date Code Marking
xx
Y = Last Digit of Year (ex: 0 for 2020) WW = Week Code (01 to 53) SMBJ12(C)AQ – SMBJ100(C)AQ 1 of 6 March 2020 Document number: DS40740 Rev. 4 - 2
www.diodes.com
© Diodes Incorporated Document Outline Features and Benefits Product Summary (@TA = +25°C) Description and Applications Mechanical Data Marking Information Thermal Characteristics Package Outline Dimensions (Note 12) Suggested Pad Layout
