Datasheet NCP500, NCV500 (ON Semiconductor) - 6
ManufacturerON Semiconductor
DescriptionVoltage Regulator - CMOS, Low Noise, Low-Dropout 150 mA
Pages / Page18 / 6 — NCP500, NCV500. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. …
Revision22
File Format / SizePDF / 199 Kb
NCP500, NCV500. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. −3.3 V. −5.0 V. www.onsemi.com
NCP500, NCV500 ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Typ Max Unit −3.3 V −5.0 V www.onsemi.com
(Vin = 3.8 V, Cin = 1.0 mF, Cout = 1.0 mF, for typical value TA = 25°C, for min and max values TA = −40°C to 85°C, Tjmax = 125°C, unless otherwise noted)
Output Voltage Vout V (TA =−40°C to 85°C, Iout = 1.0 mA to 150 mA) 3.218 3.3 3.383 Line Regulation (Vin = 3.8 V to 6.0 V, Iout = 1.0 mA) Regline − 1.0 10 mV Load Regulation (Iout = 1.0 mA to 150 mA) Regload − 15 45 mV Dropout Voltage (Measured at Vout −2.0%, TA = −40°C to 85°C) Vin−Vout mV (Iout = 1.0 mA) − 2.0 10 (Iout = 75 mA) − 80 110 (Iout = 150 mA) − 150 230 Output Short Circuit Current Iout(max) 200 540 700 mA Ripple Rejection RR − 62 − dB (Vin = Vout (nom.) + 1.0 V + 0.5 Vpp, f = 1.0 kHz, Io = 60 mA) Quiescent Current IQ mA (Enable Input = 0 V) − 0.01 1.0 (Enable Input = 0.9 V, Iout = 1.0 mA) − 195 300 (Enable Input = 0.9 V, Iout = 150 mA) − 195 300 Enable Input Threshold Voltage Vth(EN) V (Voltage Increasing, Output Turns On, Logic High) 0.9 − − (Voltage Decreasing, Output Turns Off, Logic Low) − − 0.15 Enable Input Bias Current IIB(EN) − 3.0 100 nA Output Turn On Time (Enable Input = 0 V to Vin) − − 20 100 ms
(Vin = 5.5 V, Cin = 1.0 mF, Cout = 1.0 mF, for typical value TA = 25°C, for min and max values TA = −40°C to 85°C, Tjmax = 125°C, unless otherwise noted)
Characteristic Symbol Min Typ Max Unit −5.0 V
Output Voltage Vout V (TA =−40°C to 85°C, Iout = 1.0 mA to 150 mA) 4.875 5.0 5.125 Line Regulation (Vin = 5.5 V to 6.0 V, Iout = 1.0 mA) Regline − 1.0 10 mV Load Regulation (Iout = 1.0 mA to 150 mA) Regload − 15 45 mV Dropout Voltage (Measured at Vout −2.0%, TA = −40°C to 85°C) Vin−Vout mV (Iout = 1.0 mA) − 2.0 10 (Iout = 75 mA) − 60 100 (Iout = 150 mA) − 120 180 Output Short Circuit Current Iout(max) 200 540 700 mA Ripple Rejection RR − 62 − dB (Vin = Vout (nom.) + 1.0 V + 0.5 Vpp, f = 1.0 kHz, Io = 60 mA) Quiescent Current IQ mA (Enable Input = 0 V) − 0.01 1.0 (Enable Input = 0.9 V, Iout = 1.0 mA) − 210 300 (Enable Input = 0.9 V, Iout = 150 mA) − 210 300 Enable Input Threshold Voltage Vth(EN) V (Voltage Increasing, Output Turns On, Logic High) 0.9 − − (Voltage Decreasing, Output Turns Off, Logic Low) − − 0.15 Enable Input Bias Current IIB(EN) − 3.0 100 nA Output Turn On Time (Enable Input = 0 V to Vin) − − 20 100 ms Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 4. Maximum package power dissipation limits must be observed. T PD + J(max) *TA RqJA 5. Low duty cycle pulse techniques are used during testing to maintain the junction temperature as close to ambient as possible.
www.onsemi.com 6
