Datasheet BCP56 (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionNPN Silicon Epitaxial Transistor
Pages / Page6 / 2 — BCP56 Series. ELECTRICAL CHARACTERISTICS. Characteristics. Symbol. Min. …
Revision14
File Format / SizePDF / 71 Kb
BCP56 Series. ELECTRICAL CHARACTERISTICS. Characteristics. Symbol. Min. Typ. Max. Unit. OFF CHARACTERISTICS. ON CHARACTERISTICS
BCP56 Series ELECTRICAL CHARACTERISTICS Characteristics Symbol Min Typ Max Unit OFF CHARACTERISTICS ON CHARACTERISTICS
link to page 2
(TA = 25°C unless otherwise noted)
Collector−Base Breakdown Voltage V(BR)CBO 100 − − Vdc (IC = 100 mAdc, IE = 0) Collector−Emitter Breakdown Voltage V(BR)CEO 80 − − Vdc (IC = 1.0 mAdc, IB = 0) Emitter−Base Breakdown Voltage V(BR)EBO 5.0 − − Vdc (IE = 10 mAdc, IC = 0) Collector−Base Cutoff Current ICBO − − 100 nAdc (VCB = 30 Vdc, IE = 0) Emitter−Base Cutoff Current IEBO − − 10 mAdc (VEB = 5.0 Vdc, IC = 0)
ON CHARACTERISTICS
(Note 3) DC Current Gain hFE − (IC = 5.0 mA, VCE = 2.0 V) All Part Types 25 − − (IC = 150 mA, VCE = 2.0 V) BCP56 40 − 250 BCP56−10 63 − 160 BCP56−16 100 − 250 (IC = 500 mA, VCE = 2.0 V) All Types 25 − − Collector−Emitter Saturation Voltage VCE(sat) − − 0.5 Vdc (IC = 500 mAdc, IB = 50 mAdc) Base−Emitter On Voltage VBE(on) − − 1.0 Vdc (IC = 500 mAdc, VCE = 2.0 Vdc)
SWITCHING CHARACTERISTICS
Rise Time tr − 14 − ns (VCC = 30 Vdc, IC = 150 mA, IB1 = 15 mA) Delay Time td − 9 − ns (VCC = 30 Vdc, IC = 150 mA, IB1 = 15 mA) Storage Time ts − 714 − ns (VCC = 30 Vdc, IC = 150 mA, IB1 = 15 mA, IB2 = 15 mA) Fall Time tf − 58 − ns (VCC = 30 Vdc, IC = 150 mA, IB1 = 15 mA, IB2 = 15 mA)
DYNAMIC CHARACTERISTICS
Current−Gain − Bandwidth Product fT − 130 − MHz (IC = 10 mAdc, VCE = 5.0 Vdc, f = 35 MHz) Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 3. Pulse Test: Pulse Width ≤ 300 ms, Duty Cycle ≤ 2.0%
www.onsemi.com 2
